Go Back   IH8MUD.com > General Tech Forums > Trailer Tech
Old 06-27-09, 10:53 AM   #1 (permalink)
Zack1978's Avatar
How do I replace the wood decking on my trailer?
Hi everyone,
I need to change the rotted wood decking on my Starlite trailer. My questions are 1: How do I get the wood under each lip (front and rear)? 2. And how do I secure the wood down? It looks like the wood was put in place before the end was welded on, so what do I do now?
Thanks,
Zack
Zack1978 is offline   Reply With Quote
Old 06-28-09, 02:53 PM   #2 (permalink)
shotgun's Avatar
TLCA# 11278
Cut out a section of the steel that covers your boards .1" wider than what yuo are going to use for decking . Then slide in the new boards. when your done weld back in the piece you cut out
IF IT FLYS IT DIES
shotgun is offline   Reply With Quote
Old 06-28-09, 05:23 PM   #3 (permalink)
Big Daddy's Avatar
TLCA# 2398
In the past I did exacting as shotgun indicated and it worked great on my trailer.
Big Daddy is offline   Reply With Quote
Old 06-28-09, 05:40 PM   #4 (permalink)
TLCA# 2432
I had the same problem.Cut boards out and remove one end of metal holding it in,replace boards,treated,and bolt a new metal piece in.This will allow you to one day easily replace boards when they rot again ,and they will. Mike
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
Michael Hanson is offline   Reply With Quote
Old 06-28-09, 07:40 PM   #5 (permalink)
OlympiaFJ60's Avatar
TLCA# 12028/18228
Do the boards go all the way to either end or can you slide the board forward and pull up at the end. If not, just cut out the old boards, when putting the new boards in, cut them so they can drop down all the way in the back when pushed all the way forward. Once the board is down, slide it back half the distance so each end has the same amount under the lip. Us trailer deck screws. I have found them at the local hardware store. They are self drilling, have an extra thin strip on the bit portion. Drills the wood a little wider than the screw then gets knocked off as it drills into the metal.
OlympiaFJ60 is offline   Reply With Quote
Old 06-30-09, 03:51 PM   #6 (permalink)
Old#7's Avatar
Best option in my opinion
3rd owner of a 1993 FZJ-80 funky Sliver and red two-tone. Garaged for 12 years. Stock for now. Lockers. 154K on the clock. And a Huge file of Maintenance records from day one.
Old#7 is offline   Reply With Quote
Old 07-01-09, 09:34 AM   #7 (permalink)
bigndn's Avatar
Location: where men are men and metrosexuals better be making me a CapMo.
TLCA# 18682
Are the boards long enough to pry them up in the middle and extract them that way? Replace the same way if possible. No cutting metal that way.
Chad
1976 FJ40: TBI350/SM465/SOA/SR/37" MTRs/ARBs/30-Longs/Metal Tech/SROR/Oeyes
1985 Toy Hilux: 6" lift/4.3L/R150F/Marlin's DUC/ARBs/30-Longs/5.29s/37" KM2s/Oeyes
2005 Dodge Ram 2500 CTD bullydogged, airlift
My views on Animal Rights: Animals have the right to be tasty.
Originally Posted by Mrs bigndn View Post
If it's got knockers or lockers, he'll be checking it out."
bigndn is online now   Reply With Quote
