Go Back   IH8MUD.com > General Tech Forums > Trailer Tech
Old 06-21-09, 03:14 PM   #31 (permalink)
what i learned before ordering an entire new axle is this:
you CAN adapt the hub to a different pattern, However, you cannot add a lug, so if you have 5 you cant change to 6.
In the end, i just went with a new axle. IMHO on a trailer this light , you shouldnt need brakes. drive responsibly and you'll have your increased stopping distance.
ruggedrocks.com
22nd Expeditionary Group
my FJc build : http://ruggedrocksoffroad.com/forum/...hp?topic=125.0
Phulcrum is offline   Reply With Quote
Old 10-31-09, 06:26 PM   #32 (permalink)
76 TOY's Avatar
TLCA# 12951
I ran across a place on line to get an aluminum adapter for going from 5 lug to 6 lug.
5 X 5.50 to 6 X 5.50 Wheel Adapter/ Wheel Spacer
The bad thing about them is they are 2" thick. And they are $100 each.
I have heard of using the front hub from a drum FJ40 front fine spline and getting all new bearings to fit. Then re-drilling the drum to fit over the hub.
I am trying to decide which way I am going to go myself.
Chris
Chris Bailey
'76 FJ40-350, sm420, 37" Swampers, SOA, and...
'78 FJ40 Restoration Project for my son and I
'07 FJ Cruiser, stock for now (It's my wifes...)
'06 F250 PSD 6" lift on 18's w/35" XTerrains
I'll try not to cause to much trouble while I'm here...
76 TOY is offline   Reply With Quote
Old 10-31-09, 06:32 PM   #33 (permalink)
chrisngrod's Avatar
I've seen spacer conversions for a while. I think I found some that were around 75 bucks a pop. Overall it'd be cheaper to go with a new axle. I have to look back through the thread one day and see if someone posted up better spcec for ordering through ABC.
07 FJ Cruiser (modded)
M416 modified Trailer
Webmaster Bundy Hill Offroad (Jerome, MI)
www.223photography.com
chrisngrod is offline   Reply With Quote
Old 11-01-09, 07:58 PM   #34 (permalink)
I ordered my replacement axle from Trailer Axles for utility and boat trailers. Came to $162 shipped and arrived in 72hrs from order. The spring plates were bolted to the axle flanges so I could get the locations perfect the first time. I got a 52" WMF to WMF, which they had in stock. The factory axle on my Japanese Type 73 had a 52.5" WMF to WMF. Just put your trailer on jack stands, pull both wheels off and take a measuring tape from WMF to WMF. Honestly, it should be about the same, as the Japanese trailers are almost an exact copy of the 416.
I also didn't get any brake parts, but the axle is upgradable later. When I get a burr up my arse, and sick of using wheel chocks I will rework the brake. I was thinking of adding a hydro master to the factory brake assy and plumbing it into hydro brakes on the axles.
Corprin is offline   Reply With Quote
Old 11-06-09, 08:55 PM   #35 (permalink)
Not so think as u drunk!
Hugh Heifer's Avatar
TLCA# 17468
I like my parking brake. Has nothing to do with running brakes for me.
Hugh Heifer is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/trailer-tech/259614-m416-hub-conversion.html
Posted By For Type Date
M416 Hub Conversion to 6 on 5.5? - Expedition Portal Forum This thread Refback 10-25-09 05:32 PM
