Old 03-15-08, 11:56 AM   #1
Metal Twister's Avatar
Can this Suspension Work?
Ok, so im a little different and want to try some different approaches to my trailer suspension. I thought I would throw this out for debate. Seems if I can tuck the shock up in the frame rail it should make for less chance for damage. I havnt modeled it on Solid works yet but wanted to see if it made since to the experts here. This is just a doodle not to scale or even close. There will be airbags and a detachable sway bar in the final product. Im just playing with the concept at this point.
I need your input ... Thanks in advance.
Metal Twister is offline   Reply With Quote
Old 03-15-08, 12:28 PM   #2
Niner's Avatar
TLCA# 13372
looks like the cantalever suspensions in the Monster trucks
Chris Hannis, TLCA #13372
2008 FJ Cruiser, Bud Built 5, Warn Bull Bar, 9.5TI, OME Heavies all around.
1971 FJ 40, 400 SBC, th400, Dana 20 Tcase, F/R Dana 44's, Front 4 link, rear spring over
1993 4 Runner (the Girlfriends) Stock for sale.
A bunch of stuff thats for sale
Niner is offline   Reply With Quote
Old 03-15-08, 12:35 PM   #3
release the hounds
Scott_sFZJ80's Avatar
TLCA# 13283
Nice "out of the box" thinking. How about the space above the shock, won't you need clearance for the travel? Looks like it would might get in the way of the trailer box and/or fender?
1993 FZJ80 ROTW - October 23-29 2005
Snorkel install , Skid Plate install , Rear Bumper
Scott_sFZJ80 is offline   Reply With Quote
Old 03-15-08, 12:40 PM   #4
I might have to lower the pivit point, or make it a wider frame rail? I think that I can work that out easy enough. That is the beauty of solid works. It allows you to cycle the assemblys for clearence and stress . Here are a few ideas I had for trailing arms. Since the time I drew this up Ive decided to go with a double plate for the spindel mount. That should do away with any flex, and it will also give me three good surfaces to weld on.
Old 03-15-08, 04:06 PM   #5
IH8MUD Thread Killer
Koffer's Avatar
Thumbs up
I see no problems with it . The only thing you'll need to look into is that the shock will work on the kind of angle. Most are made to be pretty close to a up/down mounting for the valving to work . Steering stabilizers would be good for this mounting setting though.
Todd
64' FJ40, 79' FJ40,(gone) 86' BJ70, 92' FJ80,(gone) 96' FZJ80
just 3 cruisers now 66'M416 and a 92' M101CND
Koffer is online now   Reply With Quote
Old 03-15-08, 06:19 PM   #6
Good thought!!! Do they make different compression and rebound rate steering stablizers?
Old 03-15-08, 06:59 PM   #7
rockrash's Avatar
You might try either a gas charged shock like one you can charge yourself,or a steering stabilzer shock they are ment to lay horizontal.Fabtech make a gas charged steering stabilzer and so does Superlift give them a try.
I like that idea for a suspension but what about the weight.Will it be able to hold 500-1000lbs.You might need a coil over shock.
rockrash is offline   Reply With Quote
Old 03-15-08, 07:41 PM   #8
The plan is to haul a couple of bikes in this thing so it will have to haul at least 1200 to 1500 lbs of weight. Add a roof tent and it will most likley need to handle a bit more. I know guys that run bags on their rigs without coilovers and they do just fine with about that much weight on each corner. Time will tell! LOL Coil over steering stablizers?? Thanks for the help.
Old 03-16-08, 10:00 AM   #9
Boston Mangler's Avatar
TLCA# 9060
Looking Good Bob!
Good call on the Horz valving question Todd!
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 03-16-08, 11:28 AM   #10
Brian in Oregon's Avatar
Reminds me of an M151A2 MUTT suspension.
1971 FJ40 w/ Chevy 350, Mark's of Australia bellhousing kit, 1979 4-spd transmission & transfer case, 12.50x33x15 tires. Rust free, original paint, wheel wells not cut.
Chit-Chat - Degrading the Ih8mud community since 2003.
Brian in Oregon is offline   Reply With Quote
Old 03-16-08, 03:54 PM   #11
Koffer's Avatar
Make it so the spindle can be bolted on like the fronts of a cruiser (ford,jeep gm etc) to be able to run large bearings and same bolt patten as the tow vehicle
Todd
Old 03-16-08, 09:44 PM   #12
I must confess I have no clue what a M151A2 MUTT is. Any Pics?
Old 03-16-08, 09:47 PM   #13
I think that is a great idea! I will check on mounting flanges and maybe adaptors?
Old 03-17-08, 01:53 AM   #14
The M151 is the Ford replacement for the military jeep. They were used in the Vietnam War. Sometimes they took the place of jeeps in war movies. Like the one John Wayne drives in "In Harm's Way" (which of course is an error).
M151 MUTT - Wikipedia, the free encyclopedia
Wikipedia has a brief MUTT writeup. The suspension I'm talking about is the M151A2, which corrected the rather squirrelly defects of the M151 and M151A1 suspensions.
Old 03-17-08, 04:02 AM   #15
inkpot's Avatar
TLCA# 10338
Howdy! Most shocks do not know about gravity. They only know compression and extension. The valving operates on pressure from either side, but not from gravity. I have seen similar setups on open desert race trucks in the good old days. Some of them even had the shocks running side to side, between the frame rails. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is online now   Reply With Quote
Old 03-17-08, 09:09 AM   #16
I am sure Im not blazing new ground here with this design. I am only thinking that something a little more unique might be the answer for me. And by original, I mean trailer wise. I dont want to have anybody worried about patent issues.
Old 03-17-08, 03:30 PM   #17
inkpot's Avatar
TLCA# 10338
Howdy! What I meant was that it IS a workable system. I think it's a neat idea. By doing some geometry, you can get a shorter shock to make a lot longer travel by using an offset bellcrank. Shocks have different valving for compression versus extension, but steering stabilizers do not. Go for it! John
CSC #41
Old 03-17-08, 07:39 PM   #18
Thanks for the input John! I am going to press foward with this idea and see where it takes me. Thanks again for the suggestions. I have been playing with the trailing arm design abit and will post up some early designs.
Old 03-17-08, 08:01 PM   #19
Colorado Boy-74-FJ40's Avatar
Every time Brian in Oregon answers a post I think it is the Professor from Gilligan's island. He thinks so deep but sure enough he's right the majority of the time.
4 Chevys and a Yota
1994 4X4 Silverado pickup
2000 S-10 pickup
2000 Monte Carlo SS
2003 Trailblazer LTZ
and a little old 1974 FJ-40
Colorado Boy-74-FJ40 is offline   Reply With Quote
Old 03-19-08, 08:35 PM   #20
Luke111's Avatar
Just curious why not just go with a proven design?
Lou
Lou
74 FJ55 ,350 Ram Jet, H55 , Ironpig Offroad Built
2007 Lexus IS350
Luke111 is offline   Reply With Quote
Old 03-19-08, 08:42 PM   #21
Luke111's Avatar
And mod to meet you needs, susp trave, load etc....
Lou
Lou
2007 Lexus IS350
Old 03-19-08, 11:24 PM   #22
Lou
Well its kinda hard to explain! But I will give it a shot. LOL While the pics that youve shown are great designs,work well, and are proven to be just fine, I have the need to excell and push the boundries. It all goes back to developing Race vechicle suspensions and trying to build a better mouse trap. With out of the box thinking, lots of ideas and conversations, along with the use of the newer computer programs, I believe that I can build a more efficient, better working suspension than what already exists. If I can free up the shock from any possible damage from ground obsticals, and at the same time build in a few more features that really work, It would be a good thing right ? And if it worked better than most, it would be more desirable, unpatented, and free to manufacture under my company name... other wise I would just do like most and copy what someone else thought hard about, marketed, fabricated, and justly so sells for a profit. That in my mind just wouldnt be cool. It's just the way I like to play the game... while always keeping in mind the easy way very seldom is the best way. Its all good and thanks for the suggestions. Bob
Old 03-20-08, 02:08 PM   #23
boss73's Avatar
TLCA# 16404
I really like this idea... Nice think out side the box and new ideas...
1970 FJ40
boss73 is offline   Reply With Quote
Old 03-20-08, 02:09 PM   #24
Luke111's Avatar
I missed your web address in the earlier post, had I look at it I would not have said a word.
Lou
Lou
2007 Lexus IS350
Old 03-20-08, 03:39 PM   #25
Lou
Heck no Lou!!! Im glad you did ask. I really need to know what people are thinking in reguards to design, products, mfg. process, ect. I know at times I come across a little rough. Its due to my inability to write. I honestly appreciate the input here. Thanks again Bob.
Old 03-21-08, 10:17 AM   #26
release the hounds
TLCA# 13283
Without "out of the box" thinking we would all still be in stage coaches.
Lou, Are those your trailers? Those are sweeeet!
Bob, curious on the length of the shock link mount to the bell crank.
