Old 03-14-08, 10:42 PM   #1
I'm really very humble
photogod's Avatar
Filling the cavity
Hey you guys with military trailers... I'm repacking the bearings and as I look inside the hub cavity between the bearings there seems to be quite a bit of room between the inner and outer bearing, 3/4 to 1/2 inch. Do you fill the cavity with grease or just pack the bajesus out of the bearings?. The M100 manual mentions just repacking the bearing and replacing it in the clean hub.
Just wondering if you have any thoughts on assembly and grease quantity inside the hub.
94 FZJ80, factory locked with mods worth more than the truck.
photogod is offline   Reply With Quote
Old 03-14-08, 11:36 PM   #2
Brian in Oregon's Avatar
When I was a kid I used to totally fill up the space with grease. Then an old timer told me that wasn't necessary. Later I had to take off a hub that I had packed, and sure enough, the bearings were turning in their own little swirl of grease, but the rest of the grease was immobile. Kinda like twirling a spoon in one spot in a jar of margarine.
So, just pack the bearings well with the proper rated grease for that application.
1971 FJ40 w/ Chevy 350, Mark's of Australia bellhousing kit, 1979 4-spd transmission & transfer case, 12.50x33x15 tires. Rust free, original paint, wheel wells not cut.
Chit-Chat - Degrading the Ih8mud community since 2003.
Brian in Oregon is offline   Reply With Quote
Old 03-15-08, 12:04 AM   #3
photogod's Avatar
Thanks.
Old 03-15-08, 11:22 AM   #4
Wagon Wheeler
TLCA# 4080
I only put just enough grease for the bearings, I don't fill the cavity to capacity.
1999 UZJ100 "the Watermelon"
Exiled is offline   Reply With Quote
Old 03-15-08, 08:36 PM   #5
gavman's Avatar
So if you are using bearing buddies then they will only work for the first or outer bearing? (Assuming you don't fill the void with grease).
Apparently its the outer bearing that fails in most cases from what i have read?
gavman is offline   Reply With Quote
Old 03-15-08, 08:39 PM   #6
What do the instructions say for them?
Old 03-15-08, 09:25 PM   #7
gavman's Avatar
Last ones I bought were from China and had no instructions but i was wondering the same thing for the last while as i just installed them on a set of hubs with new bearings.
My guess is not to fill the hubs and that the buddies are for the outer bearing and good maintenance would entail removing the hubs yearly (more often depending on milage and abuse)to re-pack the inner ones.
Mortgages | Final Fantasy MP3 | Car Insurance | American Flags | Best Credit Cards
