Go Back   IH8MUD Forums > General Tech Forums > Trailer Tech
Old 11-19-07, 09:36 AM   #1
alia176's Avatar
TLCA# 15941
7 pin plug question
I have a 7pin RV plug and was curious about the "trailer battery charge" wire/pin. What is the preferred method of providing power to this pin? This is for charging the deep cycle battery on the camper.
-fused +12vdc power direct from main battery
-fused +12vdc power from main battery switched from in cab (using a relay perhaps?)
-fused +12vdc power direct from second aux battery.
Thanks.
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Old 11-19-07, 09:39 AM   #2
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
On our company trailers we wire it into the brake light. Everytime you touch the brake it is also charging the battery for the alarms system as well as the electric brakes.
http://www.fcfabrication.com/
D'Animal is offline   Reply With Quote
Old 11-19-07, 10:07 AM   #3
450 DUDE's Avatar
Im running a circut breaker from the main battery.
seems to work just fine.
ken
97 with thingy's and dodads
Now with added geek KI6JEO
450 DUDE is offline   Reply With Quote
Old 11-19-07, 06:29 PM   #4
BC_FJC's Avatar
TLCA# 16085
Mine is direct to the main battery with a fuse... Just disconect the cable when at camp and have had no problems.
Drew
'07 Voodoo Blue FJ Crusier with a few upgrades
Photos
BC_FJC is offline   Reply With Quote
Old 11-19-07, 11:00 PM   #5
alia176's Avatar
TLCA# 15941
ken
What size breaker are you using? Is it one of those 2 pin metallic thing that resets itself?
I am liking the idea of wiring to the aux battery (via switch/relay) so that both batteries can support the trailer while parked or I can separate the two if needed.
Thanks.
TLCA # 15941
KE5LED
Old 11-20-07, 06:38 AM   #6
Put a relay on it so it cuts off with the key on the tow vehicle. That will prevent the trailer from dragging down the charge on the tow vehicle if something is using power in the trailer. Just the fact that the two batteries are different is going to cause a drain on one of the batteries if they are not activly charging. You want them seperated with the relay or an isolator if you do not use a relay.
For the run from the Tow vehicles battery to the plug use 8 gage since it is such a long run.
Most are fused at 30 amps. If it needs more then that then you need to use a external battery charger to bring it back up. Pulling up a dead battery is very rough on the alternator.
Grim Reaper is offline   Reply With Quote
Old 11-20-07, 08:18 AM   #7
alia176's Avatar
TLCA# 15941
Excellent info, thanks!
TLCA # 15941
KE5LED
Old 11-20-07, 01:30 PM   #8
450 DUDE's Avatar
Im using an aircraft style 25A breaker, (push pull style)
It can be switched to your prefrence , Im rolling with a pop up so the only real draw is when the fridge is on 12v. I have never had any issue with drain but I do make an effort to switch the fridge when ever the stop time exceeds 1or 2 hrs.
ken
Old 11-21-07, 07:23 PM   #9
Since you already have a second battery up front, I suggest a marine battery select switch - it will allow you to select any number of batteries in various combinations, or all Off. I had such a system on a Suburban when I towed a travel trailer and it worked great.
http://www.westmarine.com/webapp/wcs...ull&classNum=0
These are "make before break" switches which are very important for the health of your alternator.
Cable size is also real important - use 12 AWG at a minimum, bigger is better for less voltage drop. 30 amp RV type breakers (self resetting) are fine for each battery charge wire.
Taking power off the truck's brake circuit is fine to recharge a little emergency "breakaway" battery, but it won't do squat if you have a big "house battery" back there for a water pump and lighting.
John Davies
Spokane WA
John E Davies is offline   Reply With Quote
Read Techmeme News | PT Cruiser | Loans | Loans | Loans
