Go Back   IH8MUD Forums > General Tech Forums > Trailer Tech
LinkBack (60) Thread Tools Display Modes
Old 11-24-07, 07:35 PM   #61
drew, what a great drawing! I think i'll go with your red drawing unless i can find some already bent tube like your green drawing. wow, thx for that. Back to working on it - thx again & it makes perfect sense.
2003 Land Cruiser v8 4x4
2000 4Runner v6 5spd 4x4 - Turbo'd and Baja ready...
1999 4Runner v6 5spd 4x4
1998 4Runner v6 5spd 4x4 factory locker
1997 4Runner v6 Auto 4x4
All have Saw's/OME combo lifts & custom roof racks
My Baja Trailer Build: http://forum.ih8mud.com/trailer-tech/179520-my-baja-trailer-build.html
J-man is offline   Reply With Quote
Old 11-24-07, 07:43 PM   #62
REZARF's Avatar
TLCA# 13041
Jman, you can make the green one cheaper... I would just make the little /\/\/\/\/\ with some chopped up sections of 1/4" round rod. Couldn't be easier.
Have fun man.
Drew
Drew F.
Rising Sun 4x4 Club
Old 11-24-07, 10:15 PM   #63
northerner
semlin's Avatar
you know a couple of those 60s style decorative steel porch posts might do the trick. i wonder if you can still buy those.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
semlin is offline   Reply With Quote
Old 11-26-07, 12:37 PM   #64
ha, i was thinking the same thing! great idea.
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
Old 11-26-07, 05:34 PM   #65
Noaccount Webwheeler
Degnol's Avatar
TLCA# 14529
J-Man, I did scroll through the entire thread, but maybe missed it......Where did you get the fenders?
THX
Ed
There is nothing so depraved as a man in the depths of an ether binge
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Degnol is offline   Reply With Quote
Old 11-26-07, 05:41 PM   #66
THX
Ed
you know i forgot to mention that - i got them from MCT Trailers in Ventura, Ca for $50 each. perfect fit over the 265-75-16's BFG At's. I had ZERO rocks kick up to the rear of the tow vehicle as well - so i guess they worked well - however those traveling behind me - stayed well behind as they did get some kick ups from rocks. Might have to get some rubber yosemite sam flaps to screw on the bottom rear of the steel fenders for that prob - j/k - they'd rip off quick.
Old 04-25-08, 07:31 PM   #67
well to update this thread, ive done a couple of things.
1. I fixed the rack system and made it stronger to hold up the eezi-awn.
2. I installed a set of firestone 5000# rated air bags to aid in controlling the bounce, bottoming out, and for shnitz and giggles - so far they have really helped with loads. I am going to fab some limiting straps just so when the trailer gets some air goin down baja roads, it wont tear out the bags. Im really impressed how stout they are built - we'll see how they hold up for baja in 2 weeks when i go down mid may....
PICS TO COME tomorrow.......
Old 05-05-08, 06:31 PM   #68
REZARF's Avatar
TLCA# 13041
Looking forward to it bud!
Drew
Drew F.
Rising Sun 4x4 Club
Old 05-29-08, 11:36 AM   #69
just got back from a baja trip and the trailer suffered a little damage. Somehow i managed to bend the 3500# axle enough so that the pass side wheel was angled inward like this \. Luckily i had my airbags installed and was able to pressureize them enough for me to complete my trip down and back.
The 3500# axle from abctrailerparts.com is a 2-3/8" round tubing with 3/16" thick wall. I think im going to switch it to a 6000# rated one thats 3" round tubing with a 3/16" thick wall and then weld either a 1/4" angle bracket along the entire bottom, or some 1/4" C channel along the bottom to prevent bending of the axle - any thoughts?
Baja can take even the stoutest built things and break em. Seems like this is a constant learning curve for me - if i only had the blue prints from the adventure trailers suspension - i think they've got a bullet proof design with the independant arms w/ air bags...
Old 05-29-08, 01:11 PM   #70
I have been to Baja several times and know exactly what you mean about the abuse. Still cant believe you bent your 3500# axle. I was planning on taking my m-416 out there in October, I guess we will see how it does. Looking forward to seeing the mods your going to do. How far down baja do you go?
boctor12 is offline   Reply With Quote
Old 05-29-08, 01:50 PM   #71
yea, i was pretty amazed i was able to bend it to. Actually, i know where it happened. I was on a stretch of washboard road where i had to make a detour around a washout, then gas it to make it through and up a silty wash - and in doing so there was a spot where i got the front of the vehicle off the ground and then watched in my mirror as the trailer bounced up and came down on the pass side first, then on the drivers side. Still - the axle is a stout piece of pipe.
Driven to cabo more times than i can count, and most of the time on dirt as i like to see the coast more rather than mex1. This happened on the north road thats south of san ignacio to san juanico.
LinkBack to this Thread: http://forum.ih8mud.com/trailer-tech/179520-my-baja-trailer-build.html
Posted By For Type Date
02 4Runner T-case vent or breather - YotaTech Forums This thread Refback 10-28-08 09:10 PM
Anza-Borrego Desert State Park: BorregoFest 2008 - Expedition Portal Forums This thread Refback 10-28-08 03:52 PM
Columbus Day GWNF in pictures. - Page 2 - Expedition Portal Forums This thread Refback 10-20-08 01:47 AM
Toytec CO vs SAW's - trying to figure out whats best for me. - YotaTech Forums This thread Refback 10-16-08 03:40 AM
Untitled document This thread Refback 10-15-08 12:43 PM
Interesting problem - YotaTech Forums This thread Refback 10-06-08 05:55 PM
running boards - Page 2 - YotaTech Forums This thread Refback 09-30-08 01:16 AM
UZJ100 vs. Tacoma Doublecab - Page 4 - Expedition Portal Forums This thread Refback 09-05-08 10:49 AM
YotaTech Forums - View Profile: j-man This thread Refback 09-03-08 08:42 PM
Iceland 2008 - Page 2 - Expedition Portal Forums This thread Refback 08-27-08 09:31 AM
S/C tuning session in orange county - YotaTech Forums This thread Refback 08-26-08 06:08 PM
Hard on for turbochargers? - Page 3 - YotaTech Forums This thread Refback 08-13-08 11:28 PM
expedition/camping trailers - MallCrawlin.com Forums This thread Refback 07-17-08 11:02 AM
2006 Tundra Dbl Cab 4x4 - Expedition Portal Forums This thread Refback 07-09-08 09:02 PM
SES light!! 1998 4runner limited 3.4 - YotaTech Forums This thread Refback 07-05-08 10:23 PM
e-Locker, is it the best setup - YotaTech Forums This thread Refback 06-30-08 03:15 PM
Head Gasket? - YotaTech Forums This thread Refback 06-22-08 11:51 PM
Nicaragua: Riding into the unknown - Page 3 - Expedition Portal Forums This thread Refback 06-22-08 06:56 AM
Transmission valve upgrade - YotaTech Forums This thread Refback 06-16-08 02:57 PM
96 - 02 rear wiper motor replacement - YotaTech Forums This thread Refback 06-15-08 03:33 PM
3.4L Idle issue - YotaTech Forums This thread Refback 06-12-08 04:33 PM
panhard bar? - YotaTech Forums This thread Refback 06-08-08 02:00 AM
Baja again... - Expedition Portal Forums This thread Refback 05-28-08 06:11 PM
Front Sway Bar ends broken - YotaTech Forums This thread Refback 05-21-08 09:05 PM
Quest for all of you 3rd Gen'ers, what is your prefered year of production? why? - YotaTech Forums This thread Refback 05-06-08 10:04 PM
Just Lifted my '01... thinking about taking the rear springs back out (too stiff) - YotaTech Forums This thread Refback 05-04-08 01:45 AM
Toytec vs. ss lifts - YotaTech Forums This thread Refback 04-10-08 11:04 AM
3rd Gen 4Runner gettin 35's!! - YotaTech Forums This thread Refback 03-31-08 06:40 PM
Need Cargo Cover - 99 4Runner tan - YotaTech Forums This thread Refback 03-30-08 06:18 PM
Any tips before i install my lift this weekend? - YotaTech Forums This thread Refback 03-26-08 02:28 PM
My Baja Trailer Build... - YotaTech Forums This thread Refback 03-24-08 08:36 PM
Rough running engine, Flashing CEL, pulled codes - YotaTech Forums This thread Refback 03-24-08 12:37 AM
Chaser #1 - Expedition Portal Forums This thread Refback 03-23-08 05:45 PM
95 Tacoma 3.4L -TRD Supercharger? Help. - YotaTech Forums This thread Refback 03-21-08 01:46 AM
Chaser #1 - Expedition Portal Forums This thread Refback 03-18-08 08:54 PM
Cat back vs High Flow Muffler and Cat???? - YotaTech Forums This thread Refback 03-11-08 10:17 AM
Question for all the Stick/ 5 Spd/ Manual Drivers? - Page 2 - YotaTech Forums This thread Refback 02-25-08 03:48 PM
Just back from Central America - Page 2 - Expedition Portal Forums This thread Refback 02-19-08 06:38 AM
Purchasing a truck from out of state - question. - YotaTech Forums This thread Refback 02-17-08 01:50 AM
'98 Tacoma TRD - Worn Shocks?? - YotaTech Forums This thread Refback 02-15-08 06:46 AM
Seafoam in Fuel Tank or Injector Cleaner - YotaTech Forums This thread Refback 02-12-08 08:18 PM
My Baja Trailer build.... - Expedition Portal Forums This thread Refback 02-12-08 07:52 PM
How Many Toyota's Have You Owned? - Page 4 - YotaTech Forums This thread Refback 01-28-08 11:45 PM
Why no BFG AT's in 255-85-16? - YotaTech Forums This thread Refback 01-27-08 02:12 PM
Roof Top Tent on 3rd Gen 4runner - YotaTech Forums This thread Refback 01-23-08 07:45 AM
OME 906's - YotaTech Forums This thread Refback 01-16-08 05:02 PM
My Baja Trailer build.... - Page 2 - Expedition Portal Forums This thread Refback 01-15-08 03:50 PM
was this ebay deal too good to be true? - YotaTech Forums This thread Refback 01-13-08 05:27 PM
Well, back from dealer and my butt still hurts! - YotaTech Forums This thread Refback 01-13-08 02:15 AM
My Baja Trailer build.... - Page 5 - Expedition Portal Forums This thread Refback 01-10-08 08:32 PM
Adding to the family - YotaTech Forums This thread
