#421 |
I also have a Lock-n-Roll and I'm not sure if it is DOT certified. My trailer has a removable tongue so when on the road change it with a ball hitch it should take only a few minutes. But lets hope that the Lock-n-roll is Dot cert. LOL.. How do we find out?
__________________ Cheers, GREGNY 05 Dodge Ram 3500 SRW Diesel Kore Recon Suspension, Toyo Open Country MT's 35x12.5x17, Leer cap, Yakima rack , Expedition Series RTT 05 Chevy Tahoe Z71 (wife) |
#422 |
Steel 14ga for the floors, 16ga everywhere else.
__________________ Drew F. Rising Sun 4x4 Club 76 FJ40, 85 fj60 Engine and Ignition, 35" MTR's, Warn 8074, 4" of lift TPI, snorkeled, racked, Mini-truck P/S... and sometimes running. Friends don't let friends drive Thornbirds... My camping trailer build up thread. |
#423 |
I didn't see a DOT anything stamped into it, it has some numbers but they are for a patent. You might contact Lock-n-roll for clairity. I don't really care
#424 | |
Its not like your truck, my truck, or any of our other cruiser buddies are anywhere near DOT compliant. I won't make any nutsert jokes, but lets get going on some fab!!! Give me a ring. |
#425 |
I'm still planning on getting one of these hitches, but DOT is big out here as trailers get pulled by roving DOT pa St Troopers checking trailer reg. and for lighting, inspection etc. I contacted the manufacturer several times but got no reply as of yet. When I do I'll post it. I guess when I put the tongue of my trailer together I'll make it easy to swap out a dot compliant ball hitch for the highway.
It would just be easier if it were dot,, Now I want pics of the progress.. I was going to work on the my trailer this weekend but its outside,, and we had 4 inches of snow,, high winds and then it dropped into the single digit temps.. -4 this morning.. So until I can clear room inside mine wont be getting too much accomplished,, so,, as I said I need pics of yours! Steve |
#426 |
Mig Splatter
I have tried welding with both the straight CO2 and the Argon/CO2 mix. I do see less splatter with the mixed gas - but still get some splatter.
If you leave your rails uncoated on the inside, just make sure not to seal the tubes completely and provide a way for water to get out. Think of it like a boat trailer - The rails are either fully boxed and sealed OR C-Channel to drain the water. Trailer looks good! Anxious to see it skinned! __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html |
#427 |
KE7SBT
splatter
I have had good luck using stargon (from Oxarc: O2, CO2, AR) turned up slightly, a lot less splatter for me atleast. Has worked very well for me when welding outside with a slight breeze. According to Oxarc Star Blend - Oxarc it is used more for 3/16 + but I have had very good results welding 14, 16 and 18 Ga steel with it (combined with smaller dia wire) and the anti splatter spray, dont coat the tip with the spray though, use the nozzle/tip dip stuff to keep it clean. Just my 2 cents
good luck with the sheet metal ![]() brandon |
#428 | |
![]() Drew __________________ Drew F. Rising Sun 4x4 Club 76 FJ40, 85 fj60 Engine and Ignition, 35" MTR's, Warn 8074, 4" of lift TPI, snorkeled, racked, Mini-truck P/S... and sometimes running. Friends don't let friends drive Thornbirds... My camping trailer build up thread. |
#429 |
"The Adventure Duo"
As far as DOT for the Lock-n-Roll, a dude talks about it over on the portal as a hitch connection not having to be DOT in the USA.
Scroll down to the bottom of page 1. Trailer hitch connection? - Expedition Portal Forums Oh yeah and we have one and it works great. __________________ www.adventureduo.com [KI6LBB] 2004 Jeep Wrangler TJ X Edition 2003 Sportsmobile 4x4 EB50 |
#430 |
RE the welding splatter, i have been welding lately with the gas turned up 30% over normal and have way less problem and the welds look smoother to boot.
Worth a try
#431 | |
mike __________________ 1996 LX450 ARB, dual batteries, remote starter, 760 watt sub woofer, in dash CB, Custom switch pannel, cut and turn mod, magnaflow, custom rear bumper, rock lights, 2.5 lift, snorkle. clear side lights, CSC alum spacers, 33s, and more to come. |
#432 | |
Noaccount Webwheeler
PAM or splatter spray will make it easy to remove but he's talking about minimizing it to begin with. Adjusting gas flow and using appropriate amounts of juice will give good burn-in AND reduce splatter. .02 Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#433 |
Well, after a long day of tacking and welding in my sheet metal on my trailers front box, I am at a cross roads.
I am trying to figure out if I should weld up my sheet metal, or rivet it onto the tube frame. Pro's of welding: 1.Faster than the riveting. 2. Cleaner look than the rivets, easier to paint and prep. 3. I don't have to buy a kerbillion rivets. Con's of welding: 1. It is too cold to get my weld through primer to set up correctly. 2. Instructions call for 70*, and there is no way I can get my garage that warm, and my test piece failed miserably and came out a mess. 3. Can't get any rust proofing between the panels since its too cold to prime. 4. Controling the heat and warping issues. Pro's of Riveting: 1. I can use Sikaflex and rivets and get a super strong, water-tight bond. 2. Easy, and I don't have to worry about warpage. 3. Easier to readjust/repair/modify down the road. Con's of Riveting: 1. I loose the smooth look of the welded steel. 2. I have drill about a gazillion holes. 3. I have to buy about a gazillion rivets. 4. Could be messy with the adhesive/sealant. I am open to your thoughts... fire away! Thanks!
#434 |
If it's a"one or the other" type of decision I would go with welding. rather than rivets. Have you though of renting a heated space to do the welding in? Anyone you know have a place thats heated or work at a place with a heated shop?
I've always believed that welds are tronger than bolts or rivets. Besides, you've done such a smokin good job so far, why change now!?
__________________ Mike 98 TJ w/ Cdn M101 in tow ![]() 33 x 10.5 BFG MTs 4.88s with Super 35 & Detroit Locker 2 kids seats in back and the wife behind the wheel |
#435 |
Buy/rent one of those monster space heaters, Rivits are a pain to remove as well, still have to drill or grind them out to replace. I like the welding idea better for the strength, look and duribility.
__________________ 2003 Rubicon 4" JKS springs,JKS LCA's, JKS URCA's, JKS rear trackbar, Tom Woods driveshaft, Poison Spider Rocker Knockers,33 engineering high clearance skid, Road Armer Sahara, OR-Fab sport cage, 285/75/16 FC II's Kenwood DVD/CD GPS unit, Garmin Colorado T-Max 12k winch |
#436 |
Wagon Wheeler
I'm not a big fan of rivets, I think welding would ultimately prove a better solution, and you can still seal all welded edges with seam sealer before primer and paint.
__________________ 1999 UZJ100 "the Watermelon" 2003 UZJ100 "the Hippo" |
#437 |
ive been debating this myself have you looked into the 3m double stick stuff? i know it sounds dumb but major buildings are using it to place panels on building and its designed to be water tight, and resistant to the elements. would be a quick easy way to skin a trailer
#438 |
TLCA# Don't have one yet :)
I've been watching this build since it started.
I'm with Exiled......keep the welding. You'll have a much better looking and stronger finished product. Also, think about how rivets can work their way loose. Trailers take a BEATING, much more than the vehicle doing the towing. One thing you may consider, is to take a small blow torch (Coleman propane type) and warm up the metal....I'm here in south Denver, and I often have to warm up the steel before I take the MIG to it! .02 Jeff __________________ "Soon Ralph, Soon!" MY TOYS: 72' FJ40, Sold on eBay,guy never heard of an FJ40! :( 81' FJ40, went the way of the destructor! (parted out) 66' FJ45LV, currently being fixed back up! 02' Tacoma Double Cab, TRD SuperCharged- My Daily Driver 99' Acura TL - Wife's My Fix-up Thread: http://forum.ih8mud.com/fj45-owners-club/113621-here-goes-66-lv-restore-thread.html |
#439 |
I haven't decided yet, I am getting on the phone with Sikaflex in the morning to see what they recommend. I like the idea of welding, it may proove faster and stronger... however, with the right adhesive, it may make more sense to rivet. I am riveting some parts on either way.
Thanks guys, I'll keep you posted. On a side note it took 4 hours today to drill 6 holes to get the floor right, and it still isn't finished... been one of those days.
#440 |
you know the saying hine sight is 20/20, well i could not tell from the pic for 100 percent certain, do you have any bends on your sheet metal, then you could just over lap the bend and weld it in. Or is the plan to weld the flat sheet metal to the tubing and get a seal that way. sorry if i missed this earlier. cheers.
cheers chappy __________________ - Iam home now from the SUCK !!!!!!! VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!! - RUBITHON 2008 TESTED GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7.. |
#441 |
This one, thanks Chappy!
#442 |
go for the welding then, and try to get the garage up to temp, or heat each area first, but that can be a pain too. i understand that for sure. but you know either way is good... hmmmmm .... i would have to sit and stare at the trailer and have a few brews to get the full solution, hahhahahha
#443 |
Drew, not to hijack, but where did you source the rivnuts and how expensive was the "setting tool"?
Thanks, ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#444 | |
Hope it helps. Drew __________________ Drew F. Rising Sun 4x4 Club 76 FJ40, 85 fj60 Engine and Ignition, 35" MTR's, Warn 8074, 4" of lift TPI, snorkeled, racked, Mini-truck P/S... and sometimes running. Friends don't let friends drive Thornbirds... My camping trailer build up thread. |
#445 |
__________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#446 |
Rookie no more:)
