04-24-06, 02:41 PM
#1 | | Addict
| mig gas - CO2 vs CO2/Argon mix Anyone used both and have feedback from using both? When I was working in a shop we only ran straight CO2, and for home use I had a couple soda cylinders with plain CO2 as well.
I've read the Argon mix lays flatter beads with a better appearance and less splatter, though CO2 has better penetration.
Being a cheapskate, my inclination is to keep using straight CO2, but if I fab stuff to sell, might look more blingy with the mix.
Feedback from experience welders that have used both? |
04-24-06, 06:03 PM
#2 | | Lifer
| I have used both and will definetely only use mix only now for the most part. CO2 does spatter more and I an not convinced there is any better penetration. What is the welder you are used? |
04-24-06, 06:05 PM
#3 | | sole dictator
| used a buddies with straight and my own with mix, both the same day....
welds off my machine were definitely cleaner, he decided to switch to mix on his next tank...
__________________ Brian 'woody' Swearingen - Tie Rod Media LLC IH8MUD.com - RockCrawler.com
1996 FZJ80 "Gretchen" - 2009 HZJ79 "Headache" - 1974 FJ40 "Raisinette" - 2008 GX470 "Pearl" |
04-25-06, 01:25 PM
#4 | | Addict
| Welder is a Miller 175. In the shop we had a commercial 100% duty cycle, 3phase, 440 blah blah blah Miller mig from the 60's. |
04-25-06, 03:13 PM
#5 | | Lifer
| x3 for me on mix gas. We'd been using mix in my weld lab and the school switched to straight CO2 for a "cost savings". Had to spend more time cleaning welds after that. You can even hear a difference, Co2 pops like bacon cooking, the mix sounds more even. |
04-25-06, 08:38 PM
#6 | | Addict
| mixed, like my 7 and 7...
__________________ 1987 FJ60 - Vortec, H55, stuff - SOLD
1995 Volvo 850 Turbo - SOLD...
2006 2WD Tundra access cab
1971 Honda CB450 cafe/hooligan/trouble maker.
defender of the good, mo-fessional drunk, total art-fag, and all around nice guy... |
04-25-06, 10:15 PM
#7 | | Lifer
| Mixed on my MM175 works bueno!
__________________ 1999 100-Series...kinda modded.
2009 Kimberley Kamper Sports RV; sadly gone but to a great new home that will surely sponsor as many wonderful memories for them as it did for me. Truly one of the best possessions I've ever owned!
ROTM: spressoWAGON ROTM Blue Ribbon Coalition Life Member |
04-26-06, 03:47 PM
#8 | | 250+ Club
| mix
JR |
04-28-06, 12:48 PM
#9 | | 250+ Club
| Mix here too. Used co2, burns the crap out of ya when welding in upsidedown positions. Got the scars to prove it.(that statement makes me sound like kind of a 'tard)........
ONLY TRUE WISDOM, COMES FROM PAIN! ............. HELL YEA!
__________________ Relinguish not your past sorrow's,but furthermore thine destiny 1.('84FJ60-STEEL SLIDERS-GEN 33"s-crawler bumpers-warn-621header-custommetaltunes-202,000)DAD'S
2.('83 FJ60-STOCK-DD-180,000-ATV HAULER)SON'S |
04-28-06, 01:18 PM
#10 | | Lifer
| C25. |
04-28-06, 03:25 PM
#11 | | ow ow ow ow
| Mix is the shite fo sho. |
04-29-06, 09:50 AM
#12 | | 250+ Club
| Mix is the only way to go...
__________________ Doug
Olympia WA 1977 FJ40
1968 R60/2 W/Steib S350
1980 CT110
2009 KLR 650E9 |
04-29-06, 01:10 PM
#13 | | Lifer
| straight co2 for dual shield wire.
75/25 for hard wire.
__________________ it's only metal, we can out think it. aug69-fj40waiting for it's turn in the shop
77-fj40-currently under construction 87-fj60(10-86 build date)40k original miles, 200k aftermarket miles. apr93-fzj80 221k hers may93-fzj80170kDDer his, front and rear insulation.
tlca# 6955 |
04-29-06, 01:28 PM
#14 | | Addict
| ? The point of the flux core is for the flux to shield the puddle from the atmosphere so you don't have to use gas. Unless I'm misunderstanding what you mean by dual shield wire?? |
04-29-06, 02:11 PM
#15 | | Lifer
| you're thinking of inner shield wire, also called flux core. it requires no gas....like stick welding from a roll, instead of a rod.
we use outer/dual shield in both black and stainless varieties, but with straight co2. it's known as flux core too.
tlca# 6955 |
04-29-06, 02:54 PM
#16 | | Addict
| ahhh, thanks for clarifying. |
04-30-06, 02:16 PM
#17 | | Mod in Hibernation
Join Date: Sep 2004 Location: Where diesels purr and turbos whine
| I like the C25 mix too. Used another mix called stargold....or something like that. Prefer the C25
__________________ -84 BJ60, Set up for fun.
-91 FJ80, wife's ride [ ] [ ] [ ][___]__
|--- l l -Lo=TOYOTA=o]
()_)---()_) --o-- ()_) |
04-30-06, 03:18 PM
#18 | | Lifer
| We got talked into trying Blueshield 23 ( CO2, AR, O2) a couple of years ago and got hooked on it. Any advantage is good for amateurs like me.
BLUESHIELD 23
Allowable Impurities or Components:
BLUESHIELD 23 is a blend of argon with controlled additions of carbon dioxide and oxygen.
Applications:
-GMAW (MIG) welding of carbon steels in all transfer modes, short circuit, globular, spray and pulsed spray transfer.
-Excellent for robotic applications
-MCAW (metal core) welding of carbon steels.
Benefits:
-Reduced burn-through on very thin gauge material when welding in the short circuit mode.
-Smooth stable spray arc with low spatter and excellent bead appearance. http://www6.us.airliquide.com/cgi-bi...rodCategory=CG |
