Go Back   IH8MUD.com > General Tech Forums > Tools and Fabrication
Old 10-21-09, 03:47 PM   #1 (permalink)
small emglo type compressor trips breaker
It is not a emglo but a italian look a like with twin tanks. I think it could be the client site that could have had power issues. The comparessor would start out running very very slow, then trip the cb breaker on the compressor. The unloader valve was allowing the air to come out of the compressor and the tank bleed valve was open. Just wondering if anyone has seen a case of a compressor starting VERY slowly then speeding up??
BTW, can a AC compressor clutch be addapted to one of these small type of comressors ?
rustybucket is offline   Reply With Quote
Old 10-21-09, 06:24 PM   #2 (permalink)
fj40charles's Avatar
I'm guessing the slow running motor is an indication of problem with the motor causing it to draw too many amps.
I have 2 Emglo twin tank compressors and they've never tripped a 15 amp breaker.
69 FJ40 with some minor mods...
2000 Cummins powered Dodge with some power enhancements.
DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business!
http://www.paypalsucks.com
fj40charles is offline   Reply With Quote
Old 10-21-09, 07:37 PM   #3 (permalink)
heat em up
Are these directdrive units?
if so it has been my experience that you need to warm em up in the winter to get em to crank.
It is possible the start capacitor is shot or the start switch is broken.
In order of probability. Capacitor, Cold (I have a 1 hp Fini that wont start unless it is over 40deg f.), start switch commonly
they use external current relays so they are easy to get at but hard to diagnose.
Have you checked the obvious. What voltage is the site providing.
If this is a belt drive unit. the motor is wireable 110 or 220v (typically) Confirm it is wired properly.
remove the little plate on the back there usually is a legend on
glued to the little plate or on the main motor decal.
We used to wire ours up with a dual voltage switch. same plug
flick the switchs and instantly rewired for a different voltage.
1970 fj40 f engine 3sp w/floor shift 2.5 procomp lift 32" AT tires, Warn Bellvue winch. Evolution Blog http://forum.ih8mud.com/40-55-series...hall-plan.html
Dirtsquirt is offline   Reply With Quote
Old 10-21-09, 10:25 PM   #4 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
That is the way mine is wired. Flip a switch from one to the other.
Land Cruiser Garage Sale Items <- Link
Get Your Marlin ToyBoxes Now!
Beagle Chariot
1962 FJ40
1964 FJ 40
1968 FJ 40 <- For Sale
FJ 40.5 Build 4BT Cummins Conversion
1976 FJ 40
SPEN Trailer
D'Animal is online now   Reply With Quote
Old 10-23-09, 06:46 PM   #5 (permalink)
haryv's Avatar
This is a 110v unit. Source was 110 volts. I did not have the problem running the unit at my place. Perhaps he had wiring problems at his commercial place? Could be to much resistance sending not enough current to get my unit started.
I may just buy a etek motor to run off my 12 volt batteries to run the compressor. No need for external power.
haryv is offline   Reply With Quote
Old 10-24-09, 01:00 PM   #6 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
Is there oil in the compressor?
Can you turn it by hand?
Beagle Chariot
1962 FJ40
1964 FJ 40
1976 FJ 40
SPEN Trailer
Old 10-24-09, 03:46 PM   #7 (permalink)
4XLT's Avatar
good suggestions so far - especially the oil; is it "oil-less"? most aren't.
are you using an extension cord?
a long ext cord or an ext cord with too small gauge will increase resistance. very common to see long 16ga cords used but a tool with a high amp draw needs at least 14ga; 12ga is best especially if more than 50 ft is needed.
without proper lubrication maintenance the pump will fail, without proper amperage, the motor's armature will burn up
hth
1978 FJ43
Old steel projects I have no time for:
1965 Ford Mustang
1973 Heep Commando
4XLT is offline   Reply With Quote
