Go Back   IH8MUD.com > General Tech Forums > Tools and Fabrication
Old 10-10-09, 08:19 PM   #1 (permalink)
TLC76's Avatar
Plasma Cutting Issues
I have a Hobart Airforce 400 (same as the Miller 375 AFAIK), and I'm having issues getting an arc. I have replaced the swirl cup and tip, checked the ground, air pressure, and put my air drier on it. It won't strike an arc unless I make contact with the meatl, and then it is very blue/green and dispersed, and barely leaves a mark in the metal. This occurs on aluminum or steel. Any ideas?
Dave A
'76 FJ40, 350, SOA, PS, 37's
'05 Ram 2500 Cummins 4x4
TLC76 is offline   Reply With Quote
Old 10-25-09, 09:20 AM   #2 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
Turn up the power and double check the ground were the cable connects to the clamp. My ground wire screw comes loose all of the time on the clamp.
Land Cruiser Garage Sale Items <- Link
Get Your Marlin ToyBoxes Now!
Beagle Chariot
1962 FJ40
1964 FJ 40
1968 FJ 40 <- For Sale
FJ 40.5 Build 4BT Cummins Conversion
1976 FJ 40
SPEN Trailer
D'Animal is offline   Reply With Quote
Old 10-25-09, 05:51 PM   #3 (permalink)
TLC76's Avatar
Turned out it was my cheap ebay consumables, threw some Radnors in there and it worked fine. Now I just need to figure out how to get them to last more than 10 minutes of cutting before they're screwed up and making nasty wide sideways cuts.
Dave A
Old 10-26-09, 07:32 AM   #4 (permalink)
fj40charles's Avatar
Make sure you have a clean air supply free from moisture.
69 FJ40 with some minor mods...
2000 Cummins powered Dodge with some power enhancements.
DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business!
http://www.paypalsucks.com
fj40charles is offline   Reply With Quote
Old 10-28-09, 11:48 PM   #5 (permalink)
Chop Shop's Avatar
X2 Clean DRY air will save you troubles.
Chop Shop is offline   Reply With Quote
