09-24-09, 03:53 PM
Drilling 100 5/16" holes in steel, how?
Hey guys
I'm modding my front gate
It has a steel frame, about 1/8" thick to which 26 boards are attached. The fellows who attached the boards the first time around used cheap screws that are rusting out and letting go.
So I'm replacing with 1/4" carriage bolts.
That means that I need to drill out 26 x 4 holes. The hole size now is smaller than 1/4", maybe 1/8? I need 5/16" in order to seat the square part of the carriage bolt.
I've got a 1/2" hand drill.
I ruined 4 or 5 old bits last week doing 6 boards. Probably user error on some, though others were just plain old and worn out anyway.
So I'm going to buy some new bits before I move ahead: I'm thinking maybe Harbor Freight step bits, since the pilot hole is already there.
Or would it make more sense to just buy 2 or 3 "decent" twist bits?
Any tips/thoughts are very welcome.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Geolander MT's 33x12.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
09-24-09, 05:08 PM
buy a Drill doctor
I have a 750 model and it sharpens broken bits nicely
I have sharpened jagged broken. plain old dull bits etc.
worth the investment.
get to drilling. Step bits are nice to have but this isnt the applicaton for them in my view. You have predrilled starter hole
and very short drill duration per hole.
No sense dullling up the first couple of step on a stepp drill
09-24-09, 05:13 PM
No brag..just fact
77 '40 desmogged stock DD
78 '40 play toy with all the good shit
95 F-250 (when the tojos dont run)
02 Polaris 500ho deep wood transportion
09-24-09, 05:17 PM
Rent a magnetic drill press,it will be steady and not break bits,also use cutting oil. Mike
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
09-24-09, 06:59 PM
the nearest tool rental place that I know of is.... about 3,000 miles away.
Seriously
Ok, I'll bet that there is one in D.F. or in Panama City, maybe.
I'm stuck with what I've got, and while the job will be tedious, I'm not planning to buy new tools beyond bit(s).
My wife is in the states right now, I"ll have her bring back a couple of decent 5/16" bits, and I'll go slow/careful with some cutting oil.
Fun times ahead.
09-25-09, 08:26 AM
KC6ZWY
Try using screw screw machine or "stubby" drill bits. They have a 118 degree split point and tend to get through existing holes much easier than a regular drill. They also stay sharper longer and don't flex as much. Try Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies for a source to buy them. That's where I get a lot of the supplies for my shop. I agree with the drill doctor suggestion too. It'll sharpen the screw machine drill bits just fine and split the point.
Doug
Olympia WA
1977 FJ40
1968 R60/2 W/Steib S350
1980 CT110
1984 R100ST
09-25-09, 09:07 AM
Use your hand drill, set it up so you can't spin it at full RPM and use oil.
Speed is NOT your friend when drilling steel.
10-29-09, 07:58 AM
If you already have a pilot hole, a short 5/16 bit should go through with no problem. I buy them in a packet of 10. I'd just keep changing them, and sharpen them when I was done. I wouldn't think it would take more than 4 bits?
Toyota Land Cruiser...It's the only way I roll.
1998 UZJ100...1967 FJ40...1964 FJ45 SWB
10-29-09, 10:30 AM
where does one buy "stubby" or short bits? Sounds perfect. longer isn't better for this application as the steel is only 1/4".
oil. check.
slower drill. check.
now I just need the rain to pause for a few days.
10-29-09, 11:40 AM
#10 (permalink)
7.62mm is pretty close. Just get a 100 round clip for a SKS or AK and start drillin.
