Go Back   IH8MUD.com > General Tech Forums > Tools and Fabrication
Old 04-20-09, 10:28 AM   #31 (permalink)
Originally Posted by fj40charles View Post
What is wrong with buying quality grinders, drills, and saws? The options are not mutually exclusive.
If money isn't an issue, just go crazy on everything Snap on or Milwaukee, etc. I assume the OP is tight on cash that's why he's asking.
My point is, a $70 Milwaukee grinder isn't 7 times better than a $10 HF grinder, but a $300 Milwaukee saw is 100 times better than a $100 HF saw. Spend the money wisely is all i recommend and i did on my tools. I have HF grinders but Milwaukee saw, drills and Ingersoll Rand impact guns.
I should have re-phrase the last part of my previous reply: go cheap on the grinder and save the money TO SPEND on quality saw and drills.
ih8seals is offline   Reply With Quote
Old 04-22-09, 07:33 AM   #32 (permalink)
justweldit's Avatar
Garage
my grinders are in my hand at least twice a day , i got a second one so i would not have to change from sanding pad to grinder or slitting disc , if your just fartin around on the weekend i guess HF will do , but mine are making me money! with a 60 grit pad you press down on a 90 miter joint to grind the weld off a fancy gate in 20 seconds now do that 8 times per gate
  1. we came upon a sign, black bear road you dont have to be crazy to drive this road but it helps! song lyrics from C.W McCall
justweldit is offline   Reply With Quote
Old 04-27-09, 06:47 PM   #33 (permalink)
Junk's Avatar
Metabo. Get it.
Junk is offline   Reply With Quote
Old 04-27-09, 11:29 PM   #34 (permalink)
craptabulous's Avatar
Garage
used to run the little makita 4 1/2" until it was so hot you couldn't hold onto it with welding gloves , then you just chuck it in a bucket of water for a minute to let it cool down , get back to grinding . had that grinder for about 12 years , well i still have it .
recently i got a 400$ walter with a clutch in it , its absolutely beautiful .not saying i payed 400$ for it thats just what its worth .
i would take a milwalkee or makita over the dewalt any day , the walter is just crazy .
74 Fj40-350,sm420,60 series axles,36.5 swampers, aussie locked, saginaw.
craptabulous is offline   Reply With Quote
Old 04-28-09, 01:37 AM   #35 (permalink)
vtcruiser60's Avatar
TLCA# 15129
Originally Posted by Cruiserdrew View Post
I have used the crap out of my Milwaukee 4.5 inch grinder and it works as new. The 4.5 inch Harbor Freight grinders do not last. I also have a 4 inch Makita that's been fine but isn't real powerful.
There are two Dewalt grinders in the 4.5 inch size. The more expensive one is good.
Yeah...I have a Milwaukee 4.5 adn wouldn't look to another tool, well perhaps a Metabo....but this one will last a long time. I have burn't up two others before switching to this one.
vtcruiser60 is offline   Reply With Quote
Old 05-02-09, 05:03 PM   #36 (permalink)
BlackSmoker's Avatar
Th best grinder is a 6" Fein torque sensing and 5" Makita 9005B.
416 DoKa Mogs Real Trucks Don't Have Sparkplugs!
BlackSmoker is offline   Reply With Quote
Old 06-25-09, 07:18 PM   #37 (permalink)
I use Makita grinder and for me it works just fine. I'm not sure if it's the best, but it's good enough to suit my needs.
Rancho Steering Damper
jorgeez is offline   Reply With Quote
Old 06-26-09, 02:56 PM   #38 (permalink)
marius's Avatar
we use makitas 4.5'' and de walt 7'' in our granite shop replace makitas every 3 months de walts maybe once a year
vati kaki
1998 series 100 ,tjm front and rear bumpers with extra steel,safari roofrack spare ontop,warn winch,home made sliders and skid plates,arb locker in front,home made toolbox ,arb fridge and some other stuff like 255 /85r16 bfg mt ome 864 diff drop kit
1975 fj 40 -just give me time
Pics
marius is offline   Reply With Quote
Old 06-29-09, 08:08 AM   #39 (permalink)
Bosch!
regards
Dave
Remember as an individual you are unique.....................just like everyone else
Dave 2000 is offline   Reply With Quote
Old 08-04-09, 09:04 PM   #40 (permalink)
metabo has my vote. my brother used one everyday for 7 years still going. I have had one for two still going strong.
SSTigerMerc is offline   Reply With Quote
Old 08-04-09, 10:17 PM   #41 (permalink)
450 DUDE's Avatar
I just got a new 8 Amp 4-1/2" bosch and its super nice, havent had much time with it yet but Im expecting good things.
I also have a 4" Makita and its great , no complaint's .
ken
97 with thingy's and dodads
Now with added geek KI6JEO
450 DUDE is offline   Reply With Quote
Old 09-08-09, 11:13 AM   #42 (permalink)
Best deal out there Bosch 1803EVS 5" variable speed angle grinder
you can do more stuff with it, like stone/masonry work, diamond cutting wheels are more commune in 5" diameter, i got this one Metabo WE14-125 also variable speed, the Bosch was backorder from amazon , so put $50 more for the Metabo, there is also a newer model Metabo WE14-125 PLUS nicer streamline casing more $$. The other option but more $$$ is a Fein like lackSmoker said.
Stick with a 5" variable speed grinder you will find more uses for it. Most of them also have soft start
I also have a Dewalt 4.5 paddle switch had it for 5 years, it works but it also vibrates more than the Bosch ones i have tried.
so the order is:
Bosch $
Metabo $$
Fein $$$
This will be my choice.
2005 VX LC 80 (venezuelan build) No sunroof, no lockers, leather seats non electric, manual throttle, OEM ctr console cooler. ARB winch bumper, warn 9.5XP, TOYO MT 285, MT sliders, OME 2.5" lift kit 850/864, 4x4 Labs rear bumper, Man-A-Fre 24 aux tank, Engel MT45, dual Odyssey PC1750.
Peluo is offline   Reply With Quote
Old 09-08-09, 11:22 PM   #43 (permalink)
Radd Cruisers's Avatar
Originally Posted by Junk View Post
Metabo. Get it.
Worked in ship building company, best of the best.
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
Old 09-14-09, 06:59 AM   #44 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
bought a Metabo about a year ago so far so good but I don't use it a whole lot.
at the time Amazon had good pricing on them made it quite reasonable.
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 09-26-09, 10:29 PM   #45 (permalink)
kb3gun's Avatar
TLCA# 17295
I've been using this Hitachi from Lowes since I started my frame-off over 20 months ago. Probably have 100 hours use on it. Flap wheel, wire cup and cut-off wheels. It's my "does everything" tool and is still going strong.
Hitachi at Lowe's: 4-1/2" 6-Amp Grinder
Bill
Somerset, PA USA
2007 FJ Cruiser
1966 FJ40 :Buildup thread: Progress (or lack of) info here
Proud member of ALCA!
kb3gun is offline   Reply With Quote
Old 09-29-09, 06:13 AM   #46 (permalink)
Blue77FJ40's Avatar
I vote for the Bosch, as mine has served me for almost twenty years.
'77 FJ40: HFS, 33's, Locked and Low'd
Blue77FJ40 is offline   Reply With Quote
Old 10-29-09, 08:05 AM   #47 (permalink)
Walton's Avatar
I worked at a heavy industrial sheet metal shop for quite a few years. We used Makita grinders exclusively, and they really hold up to heavy daily use.
Toyota Land Cruiser...It's the only way I roll.
1998 UZJ100...1967 FJ40...1964 FJ45 SWB
Walton is online now   Reply With Quote
