TLCA HOME
: BOARD & BYLAWS
: EVENTS: MERCHANDISE
: BUSINESSES
: PHOTO GALLERY
: CLASSIFIEDS HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS |
#121 |
yeah, but you wouldn't know every nut, bolt, gasket or seal in the entire rig
__________________ Running total of non-waving FJC drivers ......534'85 FJ60 bone stock (the way i like it) '87 Ford Ocnorb with lots of redneck stuff & custom dented body panels |
#122 |
__________________ 1992 FJ80 7 Pin CDL Mod 265/70-R16 Maxxis Buckshot Mudders OME J's front OME Heavies Rear ProComp 9000 shocks Custom built Rear bumper & sliders http://forum.ih8mud.com/tn-stlca/198...ml#post2927590 http://Schafer_Photography.photoshop.com |
#123 | |
How 'bout a beer!
...idiot
__________________ Hugh Heifer 9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders [ And a '71 going ground up] |
#124 |
How 'bout a beer!
So I went to replace a couple of broken grease fitting today between birthday dealings and one went in no problem The second bit me in the ass. (I was going for a ten minute fix) I broke off my tap. Could not get it out, then broke of multiple drill bits. Lucky it was just a fitting in a shackle bolt. I hammerred the shards to the end of the cavity inthe hollow bolt and drilled it to accept a bigger fitting.
decided she wants to stay home superbowl/birthday and told me to work on the 40. Women, who gets 'em?
#125 | |
readin thru this thread for the first time... did you end up goin to this guy? i want to find a sandblaster that will strip the tub of my 40 after i get all the body/chop work done so i can make sure i'm not coverin up any rust lookin good, and hope those parts work out well for you. like i said last week, if you need anything let me know and i might just have something layin around. malphrus __________________ jonathan malphrus -- 72fj40 the only pinstriping i'll ever have on my cruiser will be after i hit a ny yankee 'these are my awards, mother, from army. the seal is for marksmanship and the gorilla is for sand racing.' ...build-up here (stalled)... |
#126 | |
How 'bout a beer!
Thanks for the parts. Roger still has them. __________________ Hugh Heifer 9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders [ And a '71 going ground up] |
#127 |
How 'bout a beer!
OK - grease fitting repaired. No problem, just drilled the hole considerable larger and put in a new one with an 8mm thread. Also discovered where my wire was broken for the fuel guage sender. Will be an EZ fix. I also installed the speedi sleeve over the weekend. What a PITA. Because of my set up (4 speed in an early truck) I have to drop the rear of the motor down an inch to get the parking brake drum off. I discovered it did not want to go because the collar on the tranny was binding on the tranny hump in the truck. Finally got it all apart and discovered a large amount of metal in the brake drum. Not sure where it came from or why it was there. Appears to be the drum rubbing on something and scoring but I could not identify the source of the problem. The seal looked fine but I replaced it anyway.
Got the whole shitteroo back together and drove it. No issues yet. Then the radiator started leaking out of the petcock and I noticed I still have a considerable oil leak at the front. Either the top front of the oil pan or the rear timing gear gasket which can not be removed without engine disassembly. Shitty. I will keep at it. __________________ Hugh Heifer 9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders [ And a '71 going ground up] |
#128 |
How 'bout a beer!
Found the broken wire preventing the fuel gauge from working today. Was no problem. And that is fixed. But that freaking rear output on the transfer is leaking...AGAIN! Shit. I put a new seal and speedi sleeve in there last week or when ever it was and I guess I did not get it right where it needed to go. Soooo, now what? I guess I am going to let it leak for a while.
Since the torque tube was removed once and rotated for the 4 speed mod, I may removed it and do something else becasue I can not remove my parking brake drum without dropping the rear of the engine and transmission down two inches. That is no way to have to fix things. __________________ Hugh Heifer 9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders [ And a '71 going ground up] |
#129 |
How 'bout a beer!
If anyone was wondering, this will cause a significant leak from the front of the oil pan!
When I put the pan on with the motor out I guess I m ade a rookie mistake. The front portion slipped behind the groove. All fixed. Sure is harder in the truck though. __________________ Hugh Heifer 9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders [ And a '71 going ground up] |
#130 |
At least you did't pay someone big money to to put the seal in wrong.
__________________ Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html ![]() Roger FJ-40/6.2L Diesel STLCA White Trash of the Elwood Chapter VP SFWDA |
#131 | |
#132 | ||
__________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
#133 |
How 'bout a beer!
Thanks. I am considering keeping it since it brings out the red veins in my eyes!
#134 | |
#135 |
How 'bout a beer!
Well it has been a while since I posted to this thread but that is ok.
and I took the beast out for a real test drive tonight. Filled up the gas tank - $40 muther freakin bucks fer yer ass - and thenheaded back home becasue it was over heating. Got home checked the "water" level and that was good. Think the thermostat is sticking. I assume without looking they are just like an old Ford or Chevy. The temp was fluctuating like an old truck with a bad one so I put my money there. Plus, the engine sat a long time before I got it so another reason I think it a possibility.Next - was dripping alot from the pet cock in the radiator. I have kniown about that and have avoided fixing it. That is on the list. Next - On the way home I hit the high beam switch and a fe moments later the lights went out. I guess I have a minor short. I would guess it is in the high beam florr switch since it was beat to shit and I had to do major work on it I am guessing there is an issue there. I know TPI has them so I may grab one from them. Next - I sent an old speedo housing to Poser to get it machined for two seals as that is still dripping. i took one off the three speed that has been in the back yard for a while. He tells me they are the same until you get to the split case. Finally DEATH WOBBLE! FUck. I have heard about it, never felt it until tonight. I have to do some reading and figure this out. I know my manual steering box is toast and have just about everything to do my Saginaw conversion and also have stuff for a forerunner disc brake conversion so I guess that is going to be bumped to the top of the list. Death wobble brings the suck. Hits me about 45 mph so much lower than I have read. Running 35s and all stock junk but the truck was swapped to a 4 speed. Anywho - that is where I am. Have fun in Telico again without me. I spaced it out and did not drop the freebees off for Andy in Chattanooga. Sorry bro - but fuggit - they are free
#136 |
How 'bout a beer!
Side bar - it was fun to drive it -
and my buddy and his kids could not believe it!
#137 |
How 'bout a beer!
Okay. Petcock fixed. Tried to work on some other stuff and got interupted by my buddy and his sons Nissan Altima. I had to replace the thermostat in that as well as the valve cover gasket set and plugs. None of which appeared tp be bad and I discovered after that he was way low on coolant - the burp tank was dry - and his oil level was down a bit.
I then started getting the jump seats in I bought from Wadester a year or more ago. I had to fill 13 holes the PO left me on either fender well for who knows what. I got about 6 done. I also drilled the holes for the seats and welded in some steel T nuts for the top mounts. That worked well. Maybe I will get home early enought tomorrow night to finish that. No pics thought. took the camera to Jamaice and I am Bachin' it!
#138 | |
Since it is fresh on my brain ....something to check...I just replaced my water pump and thermostat. I failed to check the condition of my fan clutch and it kept me from wheelin' last weekend. Roger was able to hold the fan while the engine was running. ![]() BTW, nice to hear you took your Ass for a test drive. Congrats! __________________ 02/83 FJ60 |
