Work of the Devil ? <brake question>
Discussion in '40- & 55-Series Tech' started by KNUCKLEDRAGGER, Aug 3, 2003.
  1. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    My 72 Fj40 keeps loosing brake fluid, there are no leaks, puddles, wet spots ...nothing to show where the fluid is going. The cap is on the fluid cup and is tight. Could the fluid be going into the booster ? The master cyl is new (1 yr) .
  2. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    New or rebuilt? I've had rebuilt fail. Yes, it can run into booster.
  3. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    It was a new one from coolcruisers, with the 1" bore (1975 and later ).
    So, if its running into the booster....then what..it fills up ? Probably eating away at the inside then ?
  4. offcamber40
    offcamber40
    279
    1
    Apr 26, 2003
    Mountains of WV
    I had one of the slave cylinders on the rear drum blow a seal.. slowly lost fluid.. Due to its location I never saw a leak.. It just kind of saturated all the brake dust in the drum and slung out while moving I guess.. no wet spots or leaks.. maybe pull the rear drum off and check? Just a thought.
  5. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    What haapens with my situation is: The truck sat for a week, I took it for a spin and the brakes felt really funny. I got out and checked the fluid and the rear cup was empty. I took it back home blead everything out and drove the truck for the day. When I parked it I rechecked the fluid and all was fine. The next weekend...no fluid, I repeated the bleeding and drove the truck, checked the fuild when I was done ..full just like before the following weekend the cup is empty. No signs of leaking anywhere (i'll check the rear cylinders this week). Has anyone had experience like this ?
    Thanks Jeff
  6. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    When I had mc leaking into the booster, it ran down the firewall, and was both in and out.
    It also comes to mind that somewhere, I think it was on the old SOR board that is referenced here, that a number of folks had bad experiences with CCOT M/Cs. I think one person even ended up with 4 of them before they got one that worked properly! (Don't ask me why they bought 4). You could probably do a search and find this discussion.
  7. dinkleberry
    dinkleberry
    303
    May 15, 2003
    Vermont
    I've heard of brake fluid going thru a bad booster and get sucked into the engine thru the vac line on a GM vehicle. Never heard of it happenin to a yota, but there's always a first.
  8. JARHEAD
    JARHEAD
    8
    Aug 7, 2003
    :mad: I just sh*t canned a new MC I bought from Cool Cruisers. The rear section never worked. Just installed a 93 fj80 MC and it works great. If your sure it's not leaking on the ground then it has to be going into the booster.
  9. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    pull the 4 nuts on the master cylinder and you will know in an instant. You dont need to disconnect anything else.
