Dirty Koala
So after getting my hands on the Wits' End TEQ emblem, I set out to start the install. It was a lot of work, but I am very pleased with the results. An unexpected benefit was the 4mpg increase in fuel mileage....bargain!
- Start by safely securing the truck on sturdy jack stands, you need the truck to not flex on the suspension for this process. (12 ton stands are my recommendation).
- For additional safety chock the front and rear tires
- Remove wedding band to eliminate risk of arcing during step 4.
- Disconnect negative battery cable(s)
- Put on you OSHA approved saftey glasses, hard hat, gloves and steel-toe footwear.
- To remove the original ARB emblem I found it beneficial to start with a thin screwdriver and 40oz dead blow hammer. Wail away on that puppy until you get the tip started.
- At this point you will have worked up a sweat, so step 6 and repeat.
- After cooling down, break out your large pry bar and get the tip started where the screwdriver left off. A few hearty pulls and she'll pop right off. (ensure truck doesn't move during this process)
- Clean surface with single malt and let dry
- Apply even pressue whilst attaching new decal, a bearing race driver and mallet works quite well.
- step 6
- Stand back and admire your handiwork.
