wiring problem
Discussion in '40- & 55-Series Tech' started by Mr Bill, Jul 20, 2003.
  1. Mr Bill
    Mr Bill
    9
    Jul 20, 2003
    I just bought a 69 fj 40. I got all of the electrical systems to work with the exception of the left rear brake light. The left rear turn and 4 way flashers work, as does everthing else. I have 12 volt power from the two green/white brakelight switch wires, but when they get to the 4 way flasher, only one wire has power. They must go through diodes or some sort of device that prevents them from back feeding power to the other wire or the front turn signals.
    I cannot get to the harness between the two switches as it is behind the steering wheel suport bracket. Any sugestions would be greatly appreciated as I do not want to remove the harness if I dont have to .
  2. offcamber40
    offcamber40
    279
    1
    Apr 26, 2003
    Mountains of WV
    Hello,
    It sounds like your problem may be more electrical related if you are not getting power on one wire, but I had a similar problem on mine after I pulled my tailight housings to paint my bumper. After I re-installed them, I couldnt get the left brake tail to work even though it worked before my tinkering.. Turned out to be a bad ground at the housing. The light is grounded to the bumper if I remeber correctly. Check to see if your lamp is grounded properly, it might be a quick fix.
    Mike
