Hey guys, anyone know where I can download a wiring diagram? I need to hunt down why my dome light doesn't work. On that note, which fuse should I check?
Thanks,
Carl
Thanks,
Carl
The fuse for the dome light is labeled 'DOME' on the cover of the main fuse box to the left of the steering wheel.I need to hunt down why my dome light doesn't work. On that note, which fuse should I check?
You'll see when you look on the wiring diagram that the 'DOME' fuse isn't labeled as such (a misprint in the publication)...it is just shown as a 5A fuse.Ha! Maybe I should have checked there first. ...thanks and thanks for the wiring diagram info.
~ Carl
see post #5 here by @Joe_E :Well this will be fun. The labels on the fuse door don't match the fuse box. I mean there are physically no fuses (or fuse holders) in the place where they should be - according to the fuse door. I'm assuming I have a door from a different year.
Can someone post a pic of the fuse door and fuse box from a 1981 truck?
Thanks!
Probably not. The inspection socket that is labeled so on the wiring diagram (over off the circuit behind the 'DOME' fuse) is around the glove box on the passenger side.Below my steering column I've found a strange "plug" that looks like it's missing something. Is this the inspection socket that the wiring diagram mentions?
Cool.Fixed! Dirty switch and a bad ground!
Cool.
Door switch or switch at the light fixture(s) (dome in front and rear)?
Was the ground a 'common' ground or did each switch on each door have it's own ground?
Where were the ground(s)?
That's a good question...I've got an 81 and couldn't find the switch on the gate either...While there, I cleaned and checked the rear light. It now works with the roof switch but not when the gate is open. Where is the gate switch?
