wiper speed
Discussion in '40- & 55-Series Tech' started by red66toy, Sep 7, 2003.
  1. red66toy
    red66toy GOLD Star
    1,517
    290
    Feb 25, 2003
    Seattle, WA
    I own a 66 FJ40 and the wiper motors on it are a little slow for my taste. I was wondering if there was anyway to get them to go faster. Also they are the original style motors. Thanks.
  2. lovetoski
    lovetoski SILVER Star
    4,426
    121
    Jul 13, 2003
    I know that on my fj60, the higher the voltage my alternator puts out the faster my wipers run. It's quite a big difference in speed between 13.5v and 14.5v. My reg was failing is how I found out. I don't know much about 40's, but if you are so lucky as to have an adjustable voltage regulator, perhaps this could help. I'm told that at much over 15 volts you can boil the fluid in the battery, so be careful if you go this route.
    HTH
  3. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    My 74 was slow so I disassembled, cleaned, and lubed it. Big improvement.
  4. Rice
    Rice SILVER Star
    3,275
    Media:
    10
    2,577
    May 2, 2003
    GSO NC
    There's plenty of room in there for friction. I'll bet like Hammerhead said that pulling and cleaning/lubing the works you'll not only get some speed but also increase motor life.
  5. red66toy
    red66toy GOLD Star
    1,517
    290
    Feb 25, 2003
    Seattle, WA
    Thanks guys for the help. I will go and try that soon.
  6. pfry
    pfry
    64
    Feb 17, 2002
    The wipers on my 68 were slow also.
    The following things all helped:
    Cleaned electrical connections in plug-in connectors. I had a bit of voltage drop across them.
    Checked and lubed the bushingg in the windshield frame, They were dry and a bit sticky
    Cleaned good out of cable between left and right sides and lubed with some lubriplate.
    Took motor apart, cleaned bushings, replaced brushes and lubed bushings.
    Took the driver's side gearbox apart, cleaned and relubed.
    The first 3 things helped the most and were the easiest.
    Fresh blades help too.
    Paul
    Wyoming
