Windshield wipers "skipping"
Discussion in '60-Series Wagons' started by Outback, Oct 31, 2003.
  1. Outback
    Outback
    606
    Sep 17, 2003
    Edmond, OK
    The patient: '88 FJ62, hers.
    The problem: The wipers keep "skipping", you know that annoying "hop" as they wipe back and forth when there's not enough water on the windshield. But they do it no matter what. :mad:
    The blades are new, infact I just went ahead and bought all new Toyota blade rails instead if refills -- the other ones looked bad. :p
    So, could it be the springs in the arms that's getting weak? I just can't see what the problem is, everything lays on the windshield nicely and they still skip. ???
    It's driving my wife nuts and I need to fix it :rolleyes:
    Any help appreciated.
    Jody.
  2. woody
    woody Carnac the Magnificent! Staff Member
    10,022
    647
    Jan 15, 2002
    Toquerville UT
    is the glass cleaned? sometimes, a residue/film can cause the skipping problem...a good scrubbing with some glass cleaner solve it.
  3. burnt03
    burnt03
    259
    1
    Oct 1, 2002
    Peachland, BC, Canada
    You could try that rain-x stuff. I used it on a trip with my old 4Runner w/ a pretty beat windshield and it seemed to make the passage of the wiper easier.
  4. Landpimp
    Landpimp GOLD Star
    14,183
    523
    Mar 14, 2003
    PNW
    get some Spot X(home Depot now sells it), it will clean all the oil, gunga and water spots off the glass. ALso even if the blades are new, take some rubbing alchool(don't drink so I can spell it) and clean the blades. Might also play with bending the arms a bit
    John H
  5. Outback
    Outback
    606
    Sep 17, 2003
    Edmond, OK
    These are all great suggestions!! I'll employ them this weekend.
    BUT!!
    Why do the wipers on my '93 FZJ80 not have any of these problems?? I don't Rain-X the windshield, I don't clean them with alcohol and I haven't tweaked the arms any. Better design? Wierd.
    Jody.
  6. woody
    10,022
    647
    Jan 15, 2002
    Toquerville UT
    older glass, more build up??? (SWAG! lol)
    BTW: if she wouldn't drive 90 mph, the wipers would contact the glass and there would be a problem...hehehe
  7. 3_puppies
    3_puppies SILVER Star
    7,729
    83
    Dec 2, 2002
    Helena MT
    could your linkage need alittle lube at the pivot points? maybe binding alittle. does it happen when your driving or sitting still?
  8. dinkleberry
    dinkleberry
    303
    May 15, 2003
    Vermont
    Use the Rain X, then when she does drive 90mph she don't need the wipers!!
  9. Ming89FJ62
    Ming89FJ62 SILVER Star
    1,277
    32
    Jul 31, 2002
    Palatine, IL
    Bet the wife takes the truck to the wash-o-truck and gets the "full" treatment which include waxing. Wax on windshield plus operating wipers = skipping and complaining wife. :D
  10. Degnol
    Degnol
    8,124
    6
    Jan 22, 2003
    Kansastitty
    Although I used rain-x on my 3.0cs, the windshield was very curved and it worked great especially at speed...BUT it left a film on the ws that nothing would take off, well almost nothing. I use 5-0 steelwool to clean a really dirty windshield. That leaves no residue and will not scratch the glass. It gets any and all old film off the thing.
    I did buy some of the Rain-X anti fog to use on the inside of the ws, since I don't have a defrost hooked up yet.
    Everybody has given you good possibilities and fixes. I'd clean the thing, check your linkage, lube it and the gears in the motor, and see what happens.
    Chattering wipers DO drive me crazy.
    GL
    Ed :)
  11. Superbark Cobalt
    Superbark Cobalt
    1
    Jul 18, 2011
    I feel like it may be due to the length of the blade as well. My car has a dominant blade; 22'' driver side and 17'' pax side. I have the skipping problem, and I think it's because on the longer blade, the top half has to travel faster than the bottom half due to the smaller area of windshield the lower half has to cover. The excessive speed may cause it to skip for the same reason the inner wheel on a 4x4 truck skips when driving on pavement. I forget the physics term for it, but it may be a big contribution to skipping.
  12. cjgoode
    cjgoode
    3,249
    108
    Jun 4, 2009
    New Smyrna Beach FL
    Clean them, most likely the cause. 409 works great, make sure you clean the windshield AND the wiper blades. Then some rainX on the windshield work help, but the main key is to also clean the wiper blades.
  13. lovetoski
    lovetoski SILVER Star
    4,280
    58
    Jul 13, 2003
    Wow - old post...revived.
    I learned from CDan that a key cause of wiper skipping is if the blade isn't exactly perpendicular to the glass. I tweaked the arms on my 60 to get them as close to 90 degrees as I could, and skipping is gone.
  14. BrentTLC
    BrentTLC
    6
    Feb 16, 2013
    Wilmington, NC
    That's exactly it lovetoski. I just did this today on my '89 62. I installed new wipers, and to my dismay, still obnoxious skipping. I then noticed the wipers weren't perfectly perpendicular. I then grabbed two pliers, grabbed them onto a cloth onto the skinny are, twisted one in the correct direction, vuala! Skipping be gone.
