Winches
Discussion in '80-Series Tech' started by Jon916996748, Jun 20, 2003.
  1. Jon916996748
    Jon916996748
    144
    Jun 10, 2003
    Columbia, SC
    I know that the Warn 10,000 or whatever will fit in the ARB bumper, but what ramseys?  I was just wondering which of those fit.  Thanks.
    Oh and what would be a good pull rate to get? This will be for moderate wheelin nothin crazy. I was think 4.5ton.
  2. wob
    wob
    2,813
    681
    Feb 28, 2003
    SC
    The warn 12K seems to be the one to get for the ARB bar.
  3. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Stick w/ Warn. Either the 12k or 15k. I used to think the Supersuckwinch X9 was a good alternative - but they suck too much to even spend $1 on.
  4. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    SW cost 1/2 the $ as the Warn so they should be 1/2 as good. If you use it 1/2 as much as a Worn it should be = to a Warn :stupid:
    kurt
  5. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    uh, yeah, it's half as good almost. little more than half of stuck if uck - put an f in front of it and that's what you'll be saying when it leaves you stuck. :takeacrap:
  6. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Only get 1/2 stuck or buy 2 SW.
    kurt
  7. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    ........................ or stay at home and not wheel :flipoff2: :pullheadoutofarse: ..hmm, guess that emoticon ain't turned on :D :D :D :D
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    :pullheadoutofarse:
    Turn it on
    kurt
  9. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    [​IMG]
    closest thing I could find next to an emoticon designed for that. maybe wench has one stored away
    hopefully you know I was only kidding though anyway. :D
  10. Jon916996748
    Jon916996748
    144
    Jun 10, 2003
    Columbia, SC
    Ok, and with the Warns what has to be done to the winch/bar to make it fit with both the 12k and the 15k?
  11. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    The winches fit fine - you'll have to drill one hole on each side of the roller fairlead. It will literally add 5 mins to your install. .... seriously, that's all there is to it.
  12. wob
    wob
    2,813
    681
    Feb 28, 2003
    SC
    So, Junk... Do you know anybody with the 15K in the ARB? I see where it's almost the same size as the 12K. Just haven't heard whether or not anybody had done it yet?
    :dunno: :dunno: :dunno:
  13. uzj100
    uzj100
    4,930
    325
    Jun 18, 2003
    Raleigh, NC
    I asked ARB USA and ARB Australia about the 15k winch and they said the normal CYA BS, the 100 deluxe winch bar has not been tested with the Warn 15k winch.
    Andrew
    Raleigh, NC
  14. wob
    wob
    2,813
    681
    Feb 28, 2003
    SC
    I asked ARB about the 12K with the 80 Series Bar. They said it could only use a 10K - Said the bar would need MAJOR mods to accept the Warn 12K. Christo from Slee set the record straight, though.
    :G :G :G
  15. Cruiserdrew
    Cruiserdrew SILVER Star
    13,605
    1,530
    Mar 15, 2003
    Sacramento, CA
    Junk is right-the 12k fits just fine. You do have to redrill the support hole in the fairlead only-do not drill the bumper itself. The fairlead is pretty heavy steel and I would estimate it ads 30 minutes to the install by the time you measure twice, and drill once(driving to the store to buy a better drill bit!). It is a very nice clean install. However, if I had it to do over again, I would buy the Slee front bumper because of the beefy recovery points and previous good experience with the Slee stuff.
  16. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Can get you a deal on a used front Slee bumper if ya want :D.
    Wob - yup, I know a guy with a 15k in an 80 series and no problem - same as the 12k. The 15k is slower and I don't think it has as much cable, but I'd go for strength being that I've stalled my 12k several times :eek: :ugh:
  17. Photo_Cruiser
    Photo_Cruiser
    266
    Apr 9, 2003
    San Rafael
    Junk...you got a used Slee front bumber....is it caked in deer guts??
  18. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    'Yup - got one - sorry fresh out of deer guts :flipoff2: hit me offline if you're interested.
