Winch Question
Discussion in '80-Series Tech' started by Mr.Bryan, Mar 28, 2003.
  1. Mr.Bryan
    Mr.Bryan
    991
    24
    Mar 28, 2003
    Tinley Park, IL
    Hey everyone, my question is on the ramsey 8000lb winch. I can get one for a good price and I am curious to know if I should go with one. I feel that 8000 lbs should suffice and its far less then half the price for a warn 10,000lb winch. I am in illinois and there is no rocks or mountains or anything other then a crap load of mud. I am probably going to get about 2 or 3 times use in one year out of the thing and I am trying to justify the extra money for a warn. Anyone have any thoughts on winches?
    -Bryan
  2. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Even if the Ramsuck only cost $100, it would be a wasted $100. 8k ain't gonna cut it. Suction on mud can't be underestimated and trust me, when you need that winch, you don't want it to fail. Get the 12k. If you can't do it now, wait till you can. Otherwise, it's like going to a go go bar with $5 :D - just ain't gonna work.
  3. Wrench
    Wrench One Bashed Up 80
    4,496
    179
    Mar 27, 2003
    Remember double your weight.
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Bryan,
     I have an 8000 lb Warn on my 80. Many of our bretheren feel that 8000 is marginal at best. They are probably correct. You must remember that a trail ready 80 with the usual mods will push 6000 lbs. 6k stuck is more than 8k rolling. That being said, if you can buy an 8000 lb winch for a reasonable price do not pass it up. You can always use a snatch block and double-up for 16000 lbs. Just  a couple of days ago I was doing some yard work for my lovely wife. (Honey will you please pull out those 3 Russian olives that are blocking my garden?).  "Sure", I said. (get to use the winch at home)
    One of them was pretty good sized. I hooked up low on it, locked all the diffs, put her in low, set the brake, and proceded to drag my 6000 lb 80 accross the yard! Obviously I was not mired in 2 feet of Caleche but an 8000 will be better than nothing............
     Regards....Dan 8)
    Hey Junk, What about $5 worth of quarters?
  5. jyoun02
    jyoun02
    21
    1
    Mar 27, 2003
    Anyone had experiences with the new Warn 9500i series winch? Just wonderin'.
    Cheers,
    John
  6. Wrench
    4,496
    179
    Mar 27, 2003
    Still not enough for an 80.
  7. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    If you need to do it on the cheap, at least get the Supersuckwinch X9. While it's only a 9k winch, the stall rating is something like 11,800 lbs. That's what I have on the rear since the 12k wouldn't mount as high inside the frame rails.
  8. jyoun02
    jyoun02
    21
    1
    Mar 27, 2003
    Yeah, for me money is a big issue. At this point I really can't justify a $1100 winch, for the occasional stuck I might experience. For now I just rely on the trusty hi-lift jack and towstraps. In the future I will most likely add a winch, but for now its more of a a cost/benefit calculation unfortunately.-John
  9. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    You will regret not having that winch when you actually need the thing.
    I have no experience in this area, it's just a hunch... :D
  10. jyoun02
    jyoun02
    21
    1
    Mar 27, 2003
    Haha, Rogue, I know what you mean, for now I will try to wheel with caution, a little common sense, and with a couple of buddies and their rigs.-John
  11. Mr.Bryan
    Mr.Bryan
    991
    24
    Mar 28, 2003
    Tinley Park, IL
    Rogue, this is true. I understand what you went through and that sucks. But I also dont have mt/r's. :D. Oh well now its time to spend more money.
    -Bryan
  12. Strider
    Strider
    47
    Mar 28, 2003
    Bryan,
    sounds like you're in the same budgetary boat as me. If you suspect you'll need a winch infrequently and can get a 8k for cheap, go with it. Buy a long cable and snatch block if you REALLY get stuck and 8k is too little, 16k of pull should get you out of it. If not, sell the 8k to a jeep owner and buy something bigger! :D
    my .02
  13. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    I've had my Ramsey Rep 8K on my last three landcruisers and haven't been let down so far. I also carry a full size shovel and am not afraid to use it, as well as try not to get into too much "Build your own African village mud". The Ramsey has been a workhorse, with no problems at all, and for general, lighter duty recovery work, you'd probably be fine. You'll need a snatch block, tree protector; shackles, etc. I think I'll probably go with a 10K or 15K Ramsey at some point in time, and move the 8K to the rear, but for now, so far so good!
    :D
    -H-
  14. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    That's right......Remember a snatch block can turn a mouse into an elephant, with enough cable, that is......... ::)
  15. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    5
    Aug 29, 2002
    Dang Dan, you've already got FIFTY posts! Keepin' up with the Jones' around here is tough! :eek:
    -H-
  16. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    If ya can't hang with the big dogs........... ::)
    PS Them aint Wrench posts either... :D
  17. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    The problem comes when your buddies attempt to "wheel" disco's and ford pickups. :mad:
  18. jyoun02
    jyoun02
    21
    1
    Mar 27, 2003
    Yeah, I can relate to that, the last time I went wheeling, a buddy and I were running a powerline trail, with some fairly steep grades and loose soil. He in a '97 dodge ram, with the 4x4 package, me in my '91. We decended the trail, which took about an hour, stopped for lunch, then decided to head back up. About a quarter of the way up, we noticed something was wrong with his rig, lots of slipping and sliding, even though he was in low range, with the rear diff locked. Well no matter what he tried he just couldn't get any traction. We had to back down the trail, which was pretty narrow, with a steep drop off to our left. When we got back to town, and took the dodge into his mechanic, it turns out a servo motor was burned out, which prevented the rear diff from being locked. Mind you, this was a rig, which while used, was in pristine condition, and had never seen dirt in its life. My cruiser was just fine through the whole affair-no big suprise there :D.-John
  19. FJ80Duo
    FJ80Duo
    168
    Media:
    1
    23
    Jun 25, 2010
    W. PA
    I just put an 8K Warn on my 80. I can get out of 8000 pounds more trouble than I could with my bare cruiser and I'm in for under a grand. I will get the double-up pulley, but I'm happy as can be.
  20. 98 SNAKE EATER
    98 SNAKE EATER
    4,436
    561
    Aug 10, 2004
    Queens, NYC and sometimes Orlando, FL
    Ramsey has always made top notch winches :cool:
    8k may or may not be enough for YOUR needs, but if you can land a good deal on it, pick it up and get a couple of snatch blocks.
    ANY winch is better than no winch at all IMHO :meh:
    If you don't feel it's up to snuff, you can always sell it or mount it in the rear :cool:
