Winch mounting question
Discussion in '80-Series Tech' started by upcruiser, Jul 9, 2003.
  1. upcruiser
    upcruiser
    334
    Mar 28, 2003
    Marquette, MI; Jackson, WY
    What does the winch sit on in the ARB bull bar? I see lots of open space, what do I need? I'm having a hard time conceptualizing it. Please help. :-*
    Your clueless but crazed cruiser upgrader,
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    IIRC the winch mounts "feet forward" on the front vertical plate(sort of around the oval hole that faces toward the front). Since you have the bar, all you need is the winch and fairlead.
  3. upcruiser
    upcruiser
    334
    Mar 28, 2003
    Now that is the kind of thing that I like to hear. Gracious C Dan, useful your information always is, yes. :)
  4. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    If I could manage it out in the bush, you can do it easy. No problem.
  5. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Up,
    First thing to do is head over to Rogue's and snag his wenchiewinch off his truck. :urinate: on it (hmm, maybe that idiocon is gone :D) then stick it in there to see. :D
    Anything that doesn't fit should just be whacked with a BMFMFFFFH ;) :D
    .... not much help I 'spose. :D
  6. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Up,
    Mounting a winch is uber-easy! I'd recommend tack welding a mounting bolt on the ARB to the bar or frame, and tacking one of the front mounting bolts for the winch to the ARB. That way, no one can unbolt the entire winch or bar and make off with it in the night...unless they have a grinder or chisel and want to make a heck of a lot of noise.
    Which winch are you getting? Saw the pics of your rig! Looks NICE! :D
    -H-
