Will this set up be ok? CV drive shaft in the rear ok?
Discussion in '40- & 55-Series Tech' started by DAD2SIX, Feb 18, 2014.
  1. DAD2SIX
    DAD2SIX
    696
    Media:
    14
    27
    Nov 21, 2012
    Layton, Utah
    Will this work ok??
    I just Put a 2f 4 speed and split case out of a 84 FJ60in my 65 FJ40
    I knew I was going to have to have my rear drive shaft shortened and my front lengthened.
    While measuring everything and getting ready to head over to the driveshaft shop I figured out that the slip yokes between the FJ60 donor and my FJ40 interchange. Giving me the correct ends to match up on both ends front and rear. Cool!
    Also noticed the front FJ60 shaft was the exact length I needed for the rear!
    So if I use it in the rear I would only have to have one shaft made for the front saving me a few hundred bucks!
    Is there any problem with using the front cv shaft in the rear?
    Anything I'm not thinking of?
    It all lines up bolts up. I think. Will be ok. What do yea say????
    The picture is of it sitting on the ground. Regular height.
  2. offcamberfj
    offcamberfj
    1,144
    Media:
    24
    17
    Aug 19, 2009
    Lovettsville Va
    I run the same thing in mine and it works fine. Ive got a lot more slip in mine though.
  3. DAD2SIX
    DAD2SIX
    696
    Media:
    14
    27
    Nov 21, 2012
    Layton, Utah
    How much slip is recommended?
  4. John Smith
    John Smith In the garage
    3,985
    Media:
    6
    75
    Jun 7, 2004
    Maryland
    Enough so you don't bottom out, and crack the transfer case apart. Fully cycle your suspension to find out if you have enough slip. Looking at your picture, you may be cutting it a little close. Are your rear springs flipped?
  5. DAD2SIX
    DAD2SIX
    696
    Media:
    14
    27
    Nov 21, 2012
    Layton, Utah
    No the springs are not flipped. I did drill another hole in the perch moving the axle back 1"
  6. Fast Eddy
    Fast Eddy SILVER Star
    13,890
    1,330
    Apr 5, 2006
    Morgan Hill, CA
    I agree that you should probably be showing more of the slip joint at ride height.
    As it sits it's out of phase too, but it matters much less with a CV joint.
  7. DAD2SIX
    DAD2SIX
    696
    Media:
    14
    27
    Nov 21, 2012
    Layton, Utah
    I'm thinking about cutting about a 1" off of the splines and cutting off the spline cover and cutting 1" out then welding the cover back on.
    That should give me plenty of travel either way. No?
  8. bikersmurf
    bikersmurf
    6,506
    Media:
    59
    272
    Apr 2, 2008
    Victoria, BC
    The old school hotroder who shortened recommended 1" of play... No problems 18 years later.
    CV would be fine. It's also easier/cheaper to shorten a shaft than lengthen one.
  9. Fast Eddy
    13,890
    1,330
    Apr 5, 2006
    Morgan Hill, CA
    No. You need to remove an inch of tube if an inch is the amount. As mentioned above you need to cycle the suspension to know how much slip you need. With a short shaft you want as much as you can get, so shortening the splines is a bad idea.
    Drive shafts aren't cheap, but once they're right, they're done.
  10. bikersmurf
    bikersmurf
    6,506
    Media:
    59
    272
    Apr 2, 2008
    Victoria, BC
    I'd drill the spring plates and move the axle back to allow 1" of yoke... Since I'm running 33s, cut wheel openings, etc... So long as it still cleared the auxiary fuel tank.
  11. DAD2SIX
    DAD2SIX
    696
    Media:
    14
    27
    Nov 21, 2012
    Layton, Utah
    If I flip the rear springs I would move the rear axle back about 3" and if I drill the perch rearward of the stock hole I would move or forward 1" netting a 2" extension. I wonder if that would be ok?
  12. bikersmurf
    bikersmurf
    6,506
    Media:
    59
    272
    Apr 2, 2008
    Victoria, BC
    Yes, the CV in the rear will work fine.
    You'll want 1" of play in the splines... 2" back would be too far (unless you've got an extra long slip joint).
    I'd keep the military wrap at the front of your spring pack and drill the spring perch and plate to move the axle back as needed ie. 1".
  13. Fast Eddy
    13,890
    1,330
    Apr 5, 2006
    Morgan Hill, CA
    Seems about right. If you want to fix the fenders afterwards, take a look here:
    http://forum.ih8mud.com/40-55-serie...r-protection.html?highlight=fender+protection
    I could do another run of these with as few as two orders.
