What is the advantage to running the ground back to the battery? Some older winches just ground through the mounting bolts to the frame. Is there a particularly good reason they stopped? You know. Assuming that at the battery side of things, you have a really good heavy gauge ground to the frame.
Particularly for a rear mounted winch. Heavy gauge wire is pricey.
