- Thread starter
- #21
We were discussing wheel manufacturers - knowing who manufactures the wheels for Toyota would do wonders to ask if they could make those wheels in stainless, wouldn't you think?huh??
What do you think of this?
Type: Wheels Size: 21" - 24" Material: aluminum alloy
OEM No.: Firestone size: 17.5*6.75 ET: inset 120 outset 141
P.C.D: 245*10 stud.dia: 26.75 C.B: 220
max load: 2500kg truck: wheel rims aluminum: wheel rim
alloy: wheel rim semi-trailer: wheel rims
I think they are made out of aluminum..
But how can you explain THAT and still say that SS is undoabe for wheels? I understand that these wheels are of a different design, but certainly the flex stresses are the same, if not greater, on a motorcycle wheel than on a car or truck!
Does anyone know how potash mines deal with corrosion issues on their mine trucks?
Many years ago, I worked in a steel fab operation that did structural work for potash mines. We used a primer that had a powdered zinc added to it for application. The remote canister of paint was constantly stirred by a pneumatic beater to keep the zinc in suspension. I remember the application was also quite tricky in that the primer tended to "land dry" on the work if pressures and distances for application were outside of proper standards.
I did a quick search on the net to see if these materials were still in use and this is a short quote from the first article I hit. Note that the primer is not suitable for sheet metal, only structural parts. Wheels and frames would be OK.
____________________________________
Zinc-rich primers provide outstanding corrosion resistance, especially in aggressive corrosive environments
Zinc-rich primers are intended for structural steel members and not for thin-gauge metal sheets, such as you might come across on your equipment.
You cannot apply a zinc-rich primer to previously painted surfaces. The primer must be in intimate contact with the clean metal, otherwise it will not provide cathodic protection to the metal.
You should not apply the primer to surfaces that contain any greases or oils.
All surfaces must be abrasive blasted to a white or near-white metal finish, and paint vendors usually recommend a blast profile of approximately 1.5-2.0 mils. If sheet metal were to be prepared in this manner, it would probably deform. Hence, the previous statement that zinc-rich metals are intended for thicker structural steel members.
After abrasive blasting the metal, you should apply the zinc-rich primer within a few hours - well before the metal can start to show signs of flash rusting.
Abrasive blasting is often not recommended or convenient when performed on existing equipment that contains motors, bearings and moving parts, because the abrasive can often find its way between the moving parts.
Inorganic zinc-rich primers come in two parts; a small quantity of a clear silicate resin in one can, and a large volume of zinc powder in the other. The difficulty faced by the painter is to intimately mix the zinc with the silicate resin. The goal is to have each individual zinc dust particle coated with the resin, but this is no mean feat if one considers how much zinc is added to the small volume of resin. Therefore, suitable mixing equipment is required and the painter must be properly trained and preferably have previous experience in this application.
[....]The only things that have worked at all are bed-liner and ceramic paint. The ceramic paint is difficult to get and expensive but extremly tough.
I think bed-liner would be the best option since its very easy to get and cheap. The only reason it didnt work in the trucks is because of the abrasion but you don't have that on wheels.
One thing that happened with the trucks is that water would get under it and corrode the metal so you would need to be careful of that. I know lots of guys on the fj forum paint wheels with Plasti-dip with lots of success. Another thing we did with the trucks that went to phosphate mines was paint the steel wheels with the same industrial equipment paint as the rest of the truck and that worked pretty well at preventing the corrosion because of the thickness of the paint. Another thing to try would be powdercoating.
Very interesting- But a factor of 10 in labour/ transformation costs? That seems unreasonable - I understand Stainless Steel is hard, but that bad? Does it break the tools or is it just simply unworkable? What part of the process is especially hard or difficult?I'm inclined to think that cost is the main reason they are not made. My company makes stainless steel products for the construction industry (these are load rated structural products, albeit not for the kind of dynamic loading a wheel sees), and the wear and tear on our manufacturing equipment is so much higher than when we make the same product out of regular zinc coated carbon steel that the cost premium is about a factor of 10. Brittleness has been mentioned in this thread, but I have not seen that with the stainless steels we use. With the right stainless (like ASTM A303) the stainless will not only not be brittle but will out preform typical carbon steel (and certainly cast aluminum) to a significant degree (strain at fracture approaching 50%). My buddy and I once fit beaver tail grip safeties to our 1911's, his carbon steel and mine stainless, and it was significantly more difficult to grind away the stainless to follow the profile of the safety than it was on the carbon steel frame. Where I live I thankfully don't share your corrosion pain but I do share an understanding for why you'd want stainless steel wheels.
