Which Shocks? New Ubolts?
Discussion in '40- & 55-Series Tech' started by Straylight, Jun 2, 2003.
  1. Straylight
    Straylight
    87
    Feb 24, 2003
    Stock fj40, doing frame off, will use it on the road to tow my duck boat .
    Doing a shackle reversal which will lift the front about 2", going to lift the rear with 2.5" over size shackles to compensate.  Just took off and trashed the shocks that were on.  Anyone have suggestions on what shocks for the front and rear?  Will do most of my driving on the road so handling and ride will be important, will not be doing any rock crawling.
    Also, any opinion on re-using the u-bolts or should I just cut them off and buy new, on second thought I just answered my own question.  If I have to ask, then get new ones.
    BTW: since I have the axles off should I go ahead and re-gasket everything?  Right now everything is tight with out leaks.
    Thanks
    Straylight
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,090
    Jan 15, 2002
    Toquerville UT
    Re: Which Springs? New Ubolts?
    best ride = OME
    highest price = OME
    Softride Skyjackers are also smooth in their 2.5 height, really most manuf's are smoother riding in the 2.5 lift range since the arch isn't as high, and high arch is the first killer of a smooth ride. Most spring lift kits come with new u-bolts and bushings, but won't come with frame-side shackle bushings to be prepared to replace those.
    I don't replace gaskets that don't leak. :G
    Soft riding shocks = Doetsch Tech DT3000's...you can order p/n's thru SummitRacing but will need to plug in the numbers direct since they don't have a listing online. Use the spreadsheet in the tech links to help determine part numbers.
  3. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    Also might consider buying a premium auto parts shock like Gabriel's or Monroes. They usually have great road manners for a decent price. I have also heard a lot of praises for the Doetsch Tech shocks. Especially from Woody :G
  4. Gus
    Gus SILVER Star
    1,127
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    In addition to everything everybody has mentioned, check out Bilstein 5100's, I run them on my tacoma and am very pleased with them. The "Billy's"(Bilsteins) have great road manners but will limit articulation some what, but since your not planning on doing much 4 wheeling that's not a big deal.
  5. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    i'm running the rancho 9000's (adjustable) and they are pretty nice. if i was going to do it over i'd run the rancho 5000's. they are a pretty smooth ride, and not to pricey.
