Wheel crisis!
Discussion in '40- & 55-Series Tech' started by cavsfj40, Apr 16, 2003.
  1. cavsfj40
    cavsfj40
    194
    Apr 16, 2003
    I ordered a set of 15 x10 rockcrawlers with 3.5 backspacing. 6 on 5.5. The guy from 4 wheel parts called and said that I need a back space of 2.5. Shouldn't the backspace be 3.5 no matter the wheel width? I need a reply here. I am running 33 x 12.50s currently and plan to go bigger
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    stock Cruiser backspacing is 3.5". There ARE rims that have occasionally required more, depending on the design of the center, however 3.5" is the recognized correct number, and a normal set of black steelies shouldn't be a problem.
    Course, there again, the BS on my new Allieds is 2"...the added width is great!!
  3. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    I think that you will be fine with 2.5" backspacing on 15x10 rims. I have 15x8 wheels with 3.5" backspacing and it's really tight to my tie rod end. I run 33x12.50 tires on mine. If I ran a 15x10 wheel with 3.5 bs then I would definately rub my TR. It would put 1" more of the wheel on the inside of the mounting surface and 1" toward the outside compared to the 15x8.
    http://www.classicindustries.com/tips/tip009.htm
    http://www.off-road.com/jeep/2001/TechWheelArt.html
    http://www.jeepmadness.com/backspacing.html
  4. woody
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    WOAH Nellie!!!
    3.5" backspacing on a 6" rim is identical to 3.5" backspacing on a 8", 10", 12", 14" etc rim.....the measuring point is the same. A 10" rim is ONLY wider on the outside edge by 2" given the same backspacing.
    Backspacing is not a measurement of where the center is located relative to the center of the rim, but rather relative to the inner mounting surface of the tire.
    3.5" is the recommended minimum backspacing, regardless of rin width. 2.5" will work fine, but your track width will be 2" wider total.
    OFFSET is a different term entirely, and in that sense Design is right...
  5. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    Oops :slap: I see what you're saying. Sorry about that...
  6. 76FJ55
    76FJ55
    46
    Apr 17, 2003
    I put a set of 15*10s on my 55 (same axles as your 40) about a year ago. with 3.5" back spacing they will set close to your tie rods but I found the reason I needed to run the 1/4" spacer was to clear the brake caliper. the factory toy rims have a domed rim web and most after market rims are relitively flat.
    good luck.
