What winch on an ARB Bumper
Discussion in '80-Series Tech' started by josharre2000, Nov 5, 2008.
  1. josharre2000
    josharre2000
    763
    Media:
    27
    6
    Sep 29, 2003
    Bentonville, AR
    Looking for reccomendations for the best winch set-up for an ARB Bullbar (winch-ready). I will not be doing a lot of hard core wheeling. However, if I do get hung up I want to make sure the winch has enough power to get the LX out safely.
    I am looking for a winch which I do not have to use spacers, etc.
    Thanks,
    Josh
  2. FJBen
    FJBen
    2,636
    Media:
    1
    5
    Apr 1, 2004
    Greeley, Colorado
    M12000 and be done.
    made for it, pulls like crazy.
  3. Sno bored
    Sno bored
    844
    4
    Jan 2, 2006
    Breckenridge, CO
    That's what I've got
  4. wearsabrowncoat
    wearsabrowncoat
    1,789
    Media:
    1
    246
    Nov 26, 2006
    San Antonio.
    If you are buying new then x3
    If you are looking for a deal on a used model then you are limiting your choices if you are not willing to use spacers.
    I just put a nice used XD9000i in and it works great but needs spacers. Still cost less than half the retail price.
  5. AKcruiserfreak
    AKcruiserfreak
    2,290
    10
    Jul 10, 2006
    North Pole, AK
    x4 I love my M12000. It's pulled me out of some sticky situations. ;)
    TK
  6. arndog123
    arndog123
    3,347
    28
    Oct 21, 2007
    Everett, WA
    I got an M12000 as well but have thought about the M15000 for a little extra capacity.
  7. Vanny
    Vanny
    996
    22
    Jan 12, 2006
    Ladner, BC, Canada
    Any pictures or details on spacer size for the xd9000i? I would really appreciate it as I have been reading a lot about the xd9000i not fitting in a n 80 series ARB.
    Thanks
  8. jonheld
    jonheld
    6,028
    749
    Dec 8, 2006
    New Jersey
    The ARB products were designed for Warn winches. The common 80 Series bumper is made for the M12K. It was originally designed around the M10K, but that has been discontinued by Warn some time ago.
    It is a no muss, no fuss installation. You want at least a 12K winch on an 80.
  9. landtank
    landtank SILVER Star
    18,181
    476
    Mar 27, 2003
    Groveland MA
    Not actually. You need to drill the bumper for the winch to mount up.
    And the warn 12k would be my very last choice, big heavy and problematic from my experience.
    If you have a 93+ truck my choice is a hydraulic. I've installed a few and it has been a flawless performer and it weighs about half as much with no need to consider a dual battery setup.
    if you do want a warn 12k I know of one that is about a year old with 0 pulls on it that you could pick up. The guy wants to go hydraulic.
  10. jdlsantos
    jdlsantos
    480
    2
    Oct 22, 2009
    Austell, GA
    The M12000 very nice, but is true so heavy.
    I going for a XP 9500.
    The ramsey patriot UT look ok, but is expensive for only 5.5HP
    follow ARB for fit any other winch diferent that M12
    "Fitment of Warn XD9000 & M8000 winch requires special spacer kit - ARB part no. 3500050."
    But really I believe that you need only couple metal spacer.
    cheers
  11. sleeoffroad
    sleeoffroad Supporting Vendor
    6,036
    484
    Mar 27, 2003
    Actually you have to drill the fairlead to move it up. Not the bumper.
    Warn also have a new 12000 lbs Endurance winch out. The form factor of a 9.5XP but 12k pulling. Might be interesting.
    [​IMG]
    Warn Industries - Ultimate Performance Series: Endurance
  12. Jule
    Jule
    171
    Sep 10, 2005
    Overland Magazine did a multi-winch test about a year ago. The Warn 12,000 lb Endrance shattered. Apparenty it is very sensitive to how it is mounted, much more so than most winches. I will dig up the exact details and post them in a day or two.
  13. 80t0ylc
    80t0ylc Hill & Gully Rider SILVER Star
    2,292
    Media:
    18
    46
    Sep 24, 2008
    Canyon City, OR
    One other detail to not overlook - the ARB was designed to use the Warn roller fairlead (P/N 5742) for proper fitment. The vertical rollers on other fair leads don't line up with the brackets on the front of the ARB. If you're planning on using synthetic line, Viking sells Delrin replacement rollers for the fairlead as it comes with wire rope rollers. FWIW Oh, and be warned - Warn accessories are $
  14. landtank
    18,181
    476
    Mar 27, 2003
    Groveland MA
    1709.99, what do they spin the windings with, gold?
    If you aren't winching all that much don't forget your snatch block. It's an easy way to double your pulling power. You sacrifice some speed but if you are only winching once or twice a year and not usually needing the the full 12k then go with a 9k instead.
  15. beno
    beno 04111-61046: I have the last one. Supporting Vendor Moderator
    19,514
    Media:
    382
    7,403
    Aug 28, 2004
    Covington, GA
    I've got an M8000 and it's been fine for every single winching situation I've ever been in. Double it to 16K with a snatch block.
  16. mtullis
    mtullis
    47
    Media:
    6
    2
    Nov 20, 2006
    Mount Airy, GA
  17. lrowe_csp
    lrowe_csp Too many cruisers, not enough time SILVER Star
    1,393
    50
    Oct 7, 2007
    Northern Virginia
    Hydralic Winch Recommendation
    LandTank/Rick:
    What hydraulic winch have you used that you recommend for the ARB bumper/FZJ 80 setup?
  18. landtank
    18,181
    476
    Mar 27, 2003
    Groveland MA
    milemarker 12k
    Here is a link to the install
  19. jonheld
    jonheld
    6,028
    749
    Dec 8, 2006
    New Jersey
    Uhhh...no. I've installed at least 6 of these in various 80s. The only drilling is the roller fairlead which is 2 holes. No muss no fuss.
    I've had mine for 10 years. I had to replace the solenoid box last summer, but other than that it always works. It gets periodic maintenance every 2 or 3 seasons.
    Yes, it's big and heavy. So's my truck. No such thing as too much recovery power.
  20. kup99
    kup99
    1,046
    Sep 30, 2006
    Calgary Alberta Canada
    Same here.. It's all good for me!!
