That is not correct.JetB is a mix of Avgas and Avturbo fuel.
In every part of Canada Jet B is described by Canadian Specification CAN/CGSB 3.23.Perhaps that's the case where you are and your description is the traditional form of JetB. However here in N. Canada since the demand for 'traditional' JetB has diminished significantly, the refineries are not producing JetB anymore so the suppliers are simply combining avgas with avtur [JetA] to meet the JetB requirements. In the future make sure you have all your ducks in a row before you decide something 'is not correct'.
Considering that I am correct I am sure I will.Believe whatever you want to. This conversation is pointless.
JetB is a good winter additive for biodiesel fuel mix to lower the gel point temperature, but unfortunately it can be difficult to find, fortunately gasoline is almost as good.Has anyone used JetB or a JetB mix in a diesel here.
I have lots available to me but I havent found a recipe
specific to Jet B.
There are lots of people using Jet A and either adding nothing
or just a lubricity additive.
Not computer controlled. Simple mechanical control is best for alternative fuels. If operating in cold temperatures then an inline IP is best. B and H series Toyota engines are good examples.What is ideal for a bio-diesel engine? If you were looking to drop in a diesel and one of the main criteria was compatibility with bio-diesel what would you look for? What engines fit those categories, Toyota or otherwise?
That might be, however it's nasty stuff to handle, and is usually contaminated with water which has to be removed.As I understand it, old stale gasoline is best, I think because it has a lower flash point and is less prone to premature ignition etc. Or something like that.
jetA1 has insufficient lubricity for piston engines, and wear will increase, especially the IP. I suggest adding at minimum 5% biodiesel or clean veg-oil.
I run a 13B-T on fuel mixes containing biodiesel, veg-oil, jetB, and ULSD.
I run B100 in my 1hz 5-6 months out of the year and reduce as temp drops... Dead of Maine winter I run B10-B15... Has yet to leave me stranded in the cold. I replace all the lines with viton lines when I dropped the engine in.... .
