what tire size can I run
Discussion in '40- & 55-Series Tech' started by wayne_fj40, Jan 8, 2003.
  1. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes a friend of mine has some 36" super swampers Ibelieve tsl's.Iwas wondering with a 4"bds lift and If I made some 2-2.5"shackles and when Icut the rear wheel well out for my fender flares will Ihave enough clearanceor will I need to do more
  2. zach1972fj40
    zach1972fj40
    48
    Jan 3, 2003
    I beleive that you could with the cutting of thew fenders but it might be close.
  3. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    I agree with Zach. I run a 4" Skyjacker lift with 33's and I clear them no prob. I could probably run 35's if I cut my rear fenders. So I would say that 4" springs + 1.5" shackle lift + rear fender cut would equal enough room for 36's. Give it a try. If it doesn't you could fab up a small 1" body lift to do the trick. You might be careful putting shackles on the front of the rig, it will magnify any loose steering problems. Might consider doing a shackle reversal as well. Good luck man!
