What size gears?
Discussion in '40- & 55-Series Tech' started by godzilla, Sep 12, 2003.
  1. godzilla
    godzilla
    254
    Apr 20, 2003
    I have a 74 fj40 that I'm doing a soa and a disc conversion on. I fiqured now would be a good time to put lockers and gears in. What ratio gears should I use. It will have 35's on it and will be driven on and offroad. I saw manafre has 5.29's available. Thanks
  2. Cruiserdrew
    Cruiserdrew SILVER Star
    13,585
    1,510
    Mar 15, 2003
    Sacramento, CA
    Well-do the math. For 35 inch tires, 4.56 gearing will give you 65 mph at 3000 rpm. 5.29 gears are weaker due to the small size of the pinion head and are really too low for these tires in a street driven FJ-40. You could even stick with the 4.11's for better highway performance, but you will give up some "grunt". In my opinion, the 4.56's would be just about perfect, assuming you stick with 35's. In your position, with soa, I would be tempted to try 37's and 4.88 gears. Check out the gear/rpm tables on the TLCA website.
  3. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    What engine is being used?
  4. jm
    jm
    75
    Mar 30, 2003
    With 38.5s, welded rear, 350tbi and an sm465 Woody's running stock 4.11s... seems to hold 55-60 fine.
    With 36s, 2f, stock 4-speed and 4.88s I've been happy, although the sm420 needs to go in to slow it down in first. It's scary to drive it above 50ish (sort of a death wobble at various speeds from unbalanced tires) so rpm's aren't an issue. Not real streetable anyway with the welded rear... tires tend to howl pretty bad turning corners.
    jm
  5. godzilla
    godzilla
    254
    Apr 20, 2003
    It has the orginal straight six, with the 3 speed tranny and transfer.
  6. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    With 5.29s and 35s you be turning over 3000 RPM at 60MPH.
