What Oil do you guys use
Discussion in '40- & 55-Series Tech' started by 77cruiser, Jan 17, 2007.
  1. Got a 77 with the 2f, pretty old never rebuilt but runs good. What weight oil are you guys running? 10w-30? or something better for older engines?
  2. igotta40
    igotta40
    607
    Houston, TX
    20 w- 50 Shell Rotella AFAIK it does not have depleted levels of ZDDP, better for solid lifters & camshafts.
  3. projektdotnet
    projektdotnet
    1,872
    Port Orchard, WA
    i use 10w-30 or 5w-30 depending on what is in stock that day
  4. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    19,624
    MN
    15-40 or 20-50...all year.
    5-30/10-30 oil is too thin when it gets hot....
  5. whatever is on sale at the time
    10-30
    5-30
    15-40
  6. BC Cruiser
    BC Cruiser
    212
    Maple Ridge, BC
    I second 20-50w, it was the only thing that kept my oil pressure up.
  7. F-junker
    F-junker
    1,774
    Hagerstown MD
    I've heard that this oil is great for older vehicles due to the zinc content for as you mentioned cam and lifters. It has been recommended for older big block vettes and I'm going to be changing over to it soon. (The Shell Rotella oil) I believe that it's a diesel engine oil.
  8. sepr2
    sepr2
    406
    Duluth Ga.
    I think the area of the world you live in would have to figure into the picture. As well as miles on the engine. Exteme cold or high temps would seem to make a difference. Thicker oil seems to help with oil pressure as well with older engines that may not have been taken care of in years past. I use 20w50 but have more hot than cold. I think changing it regularly is the most important issue...
  9. grant5127
    grant5127
    5,021
    Meridian,TEXAS
    :cool:
  10. bandy rooster
    bandy rooster
    1,925
    Sunny South
    20w50 pennzoil plat. synthetic
  11. Cruiserdrew
    Cruiserdrew SILVER Star
    11,683
    Sacramento, CA
    I don't put high dollar oil in my FJ40. Instead, I use the Chevron Supreme 20w-50 all year. THese are tractor motors and not picky about oil. BTW-If you watch the ads, you can get the Chevron for $0.49 per quart after rebate. It's cheaper than gasoline. If I were lucky enough to get an engine rebuilt, I would run Chevron Delo 15w-40.
  12. bsevans
    bsevans Focus on the Journey SILVER Star
    2,011
    Southern Arizona
    20w-50 Castrol for 21 years
    The last oil change I decided to use Chevron Delo 400 LE SAE 15W-40 which is the same oil I use in my 6.5L turbo diesel.
  13. numtel
    numtel
    400
    Chico, CA
    I was running 20-50w then just changed my oil and since it's winter I used 10-30w. That was a mistake. Before, I could keep oil pressure on my side better. Now I had to turn off the engine and winch pretty quickly when it was leaned way over. Obviously, I will be using 20-50w next time.
  14. tucker74
    tucker74 Moderator
    3,934
    Austin, TX
    Chevron Delo 10W-40 in the tractor motors ... don't waste your time with synthetic unless you've recently rebuilt. I use all synthetic in the 80 -
    Tucker
  15. John Smith
    John Smith In the garage GOLD Star
    3,824
    Maryland
    20w-50 Castrol GTX all year but if it were cold I would run 15w-40. I am interested what oil pressure you guys running 30 weight oil are maintaining. That is a very thin oil for the clearances in these motors.
  16. dfmorse
    dfmorse
    1,518
    EVERGREEN, CO, USA
    10-40 semi-synthetic
    Castrol works good.
  17. hatman406080
    hatman406080 SILVER Star
    1,529
    up on the MTN.in California
    '75 fj40 140,000+mi. 20/50 Castrol GTX.
  18. JohnnyC
    JohnnyC Long ago TLCA# 2231 SILVER Star
    10,719
    Albany, NY area
    74 fj40 w/433,000+ miles ....20w50 with 2 cans of no smoke :)
  19. wct49
    wct49 POWERED BY AMEX SILVER Star
    6,234
    39073 under the Paul B.
    Castrol 20W50
    Chris
  20. IDave
    IDave
    7,199
    McCall, ID
    Also. No problem starting up at -20F the other day. (Some guy with a "modern" vehicle said he couldn't start his because he had 10W30 instead of 5W30 and had to have his oil changed out. :rolleyes:)
Share This Page
