just a guess and probably wrong but rear heater, driver seat belt connector, o2 sensor
Thank you, I think you're correct. Looks like the green connectors could be for the seat belts and the others could be the rear heater.
Jumper power to the fuse block and see if it runs...?Ive found that I do not have power to the fuel pump. The after market fuel pump on the passenger side of the chassis. Ive traced it back to a fuse block up next to the battery (labeled "Power to Fuel Pump") but lost if upstream from that.
The wire disappears with a large group of wires between the motor and firewall. Under the dash there is a mess of ALOT of wiring.
Any advice on how to trace the one out? Ive looked ( or attempted to) up wiring diagrams from Painless Wiring Harness for the 1995 5.7 TBI but had no luck.
thought about restoring the hard top. then thought about converting to soft top. then thought about restoring the hard top.
Just means you need two cruisers one soft top and one hard topThis is my constant debate. Then there is aftermarket vs OEM style soft top. When you look at the later you are thinking price wise why don't I get an aftermarket (bestop) and restore the hard top. Then you start thinking about the hard top again. Then soft... It never ends. Good luck!
I had a bestop soft top... Hated it. It leaked, flapped, and was a B1TCH to put back on if you lowered it... On a sunny day it was doable, but cold and wet, forget it.
Hard top... Or a rigid bikini top...
