Beside the obvious of looking cooler, what is the advantage off road of a larger diameter tire. Lets just assume the 33 and the 35 are true to size. With a 2 inch diameter increase there would be 1" additional clearance under the axle and the body. This is the obvious advantage.
But what about the angle in which they role over a object? If you say have a 12"rock and run up to it in a 24 inch tire you will be hitting it right at the vertical part of the tire. If you hit the same 12" rock with a 48" you will hit it with a angle of the wheel which roles up and over it much better.
This is a extreme example but does it come into play with changes as small as 33"-35" in the real world? I guess i am asking does a slightly larger wheel, 33-35, change more than just the extra 1" clearance? Is there a real world improvement of how it roles over obstacles or is it minimal in real world?
