What do good hard doors cost?
Discussion in '40- & 55-Series Tech' started by 78crzr, May 8, 2003.
  1. 78crzr
    78crzr
    657
    1
    Apr 6, 2003
    Tomball, TX
    Ran across some really clean hard doors which were from a 1978 FJ40. No real rust(a little surface about the size of a dime) and the door panels, windows, etc. were all in really good shape. Still had the original paint. The seller wanted $400.00 each. How does this price compare to what all of you have seen clean used doors go for? Also had some doors off of a 1973+/- that were the "old style" for about $275.00 each. Which would be better for a '78 FJ40? Thanks.
  2. nuclearlemon
    nuclearlemon not an addict Moderator
    15,585
    Media:
    87
    404
    Jan 30, 2003
    meh-ico, colorado
    i'd hold out if i were you. you can find great doors for $400/pair and good doors for $200/pr
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    DEFTINATLY go with the doors off the '78. They have better windo regs, and are monoframe which doesn't rattle like the pre 75 doors. I am hoping to sometime put 75+ doors on my '74, they just rattle to damn much.
  4. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Bailey, if rattles are your main problem, you may want to try doing adjustments before you buy new doors, or you could find yourself with the same problem. New seals, and adjustment of the hinges is critical. Each hinge has 4 bolts inside and 3 bolts outside which can be used to realign the doors, and the latch is adjustable, too.
    If my rattletrap doors could be totally quieted, I expect yours can, too!
  5. ledge
    ledge
    38
    Nov 17, 2002
    I got a set of really nice doors for 200. new glass, and good metal. I think you could find some good ones for cheap if you keep looking.
  6. Gus
    Gus SILVER Star
    1,127
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    $400 for each door is too much, for the pair OK. The 75 + doors are all around much nicer. :p
