what causes a hole in a piston
Discussion in '40- & 55-Series Tech' started by pvaman, Sep 21, 2003.
  1. pvaman
    pvaman
    129
    Apr 11, 2003
    85FJ60 - 200K miles. Pulled the head and one of the pistons has a fairly good sized (1/2 sq cm) hole in it. What can cause this...a vacuum leak? ???
  2. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    Pre ignition, timing too far advanced, will burn a hole in a piston. Vacuum leak isn't a big problem unless you're trying to get a smooth idle. A big vacuum leak would make it run lean and hot, but I don't know if it would burn a hole in a piston.
    Ed Long
  3. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    A vacuum leak can cause pre-ignition.
  4. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    #5 or #6 piston? IIRC, a bad vacuum booster can cause enuf of a vacuum leak to trash a piston...
  5. pvaman
    pvaman
    129
    Apr 11, 2003
  6. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Normally bad boosters are pretty obvious though. Hissing like a pissed snake. How are your brakes pvaman?
  7. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Do any other pistons show signs of pitting?
  8. dd113
    dd113
    2,923
    1
    Jun 13, 2003
    I would bet it was a bad booster or even a good booster drawing on the back 2 cylinders. I have no idea why this happens. It might be that the vac for the booster causes it to run lean but I cant see why this would hole the piston. Could also be a small part of a plug that got in there.
  9. bobrose
    bobrose
    11
    Sep 2, 2003
    Don't remember off the top of my head what symptom points to what but the type of hole it is can be telling. A hole that looks like it was punched out (fractured edges) vs. a hole that looks like someone took an acytelene torch to it.
