Weird vibration
Discussion in '80-Series Tech' started by Taz, Aug 12, 2003.
  1. Taz
    Taz
    342
    Mar 27, 2003
    San Juan Capistrano
    I have a weird noise coming from what seems to be the front of the 80. I have the J springs and 1.5" spacers in the front. The noise occurs while driving down hill at 55+ with my foot barely on the accelerator, just at the point where there is no load on the driveterrain. It sounds like air passing over the end of a tube. I can feel the vibration in my feet more than I can hear it. Is this a common noise/problem related to bad birfields? I tried removing the front driveshaft, this reduced the noise only slightly.
  2. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Not sure about driveline noise, but I had a weird vibration/noise coming from the wheel well a while back that turned out to be the rubber/plastic shield (for lack of a better description) that's fitted to the back and inside of the wheel well. It had come loose and was wagging back and forth in the wheel well when I got going fast enough. Might want to check that sort of thing out before tearing into anything.
    Tom
