weber carb for an FJ60
Discussion in '40- & 55-Series Tech' started by Hayncruzr, Mar 21, 2003.
  1. Hayncruzr
    Hayncruzr
    1
    Mar 21, 2003
    Which weber should I use 32/36 or 38? I want better mileage, and would like at least a little more power than my stock carb. By the way I will be adding headers too.
    Mahalo (thanks)
  2. brian
    brian SILVER Star
    7,343
    770
    Feb 7, 2003
    lebanon,pa
    i got a 38 but it's not on yet
  3. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    i have heard that the 32/36 is better, but i've also heard the 38 is better. I would personally go with the 38, but everyone else feel free to chime in
  4. dieselcruiserhead
    dieselcruiserhead
    2,666
    4
    Jan 2, 2003
    Park City, Utah
    I have run both and the 32/36 delievers good power and good milage.  The 38 can deliver very good power (especially when coupled with a good ignition and headers) but is near impossible IMO to get good milage out of.  But on another note my roommate's 38 gets about 16+ MPG on his 4.2 CJ7 (but he has a 5th gear and a lot less weight) while I'm struggling to get 15 MPG.  Good luck!
  5. devo
    devo
    886
    5
    Nov 3, 2002
    denver
    According to some of the Toy shops the 32/36 is not big enough for the 2F and you won't see a Webers full potential unless you use the 38/38. That's what I found out prior to running mine. And yes it made a huge difference when combined with a header. But now I have switched to a V8.
    I have my 38/38 (complete) for sale if your interested.
    Devo
  6. plan66
    plan66
    31
    Jan 28, 2003
    I'm running a 32DIR Weber on my F. It is on the small side I guess, but I'm very happy with it, and it has more airflow than the single barrel it used to have. The engine is otherwise stock and I rarely find I need to open the secondary barrel. Personally I'd not buy a 38 synchronous openning carb if fuel economy matters to you. Stick with the 32/36 progressive carb, set the primary barrel slightly weak, and the secondary richer for when you want WOT. On the other hand, if you want more power and drive such that you use it, your economy will suffer either way. By the way, I average 15mpg now, but when I was setting the carb up it bettered 17mpg on the hwy. Only problem was it was so lean it didn't have enough power to spin the tires on gravel!!! :eek: :-[
