Water Pump or Heater Line?
Discussion in '80-Series Tech' started by Hltoppr, Apr 14, 2003.
  1. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Ok, arrived at work this morning to find a copius amount of coolant draining from the front left (US DS) of the engine compartment. Radiator Hoses are good.
    Leak seems to be coming from the general vicinity of the water pump; however the shaft seems tight, w/no up/down movement, and no "squealing" noise when running.
    The coolant seems to be running down one of the metal lines on the left side (again from the US DS), soaking the PS pump.
    My gut reaction is to order a new pump and line, just to be sure I've got the right part, and replace as necessary when I get in there. Anyone had the lines go out before? Any hints on which component may be leaking? :dunno:
    Wouldn't ya' know it that a run is scheduled in Sedona, AZ this weekend, so I'll be putting in some overtime work on the cruiser.
    -H-
    (Helluva way to start a Monday...)
  2. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Since you say it's on the DS, can you tell if it's coming from around the throttle body? If memory serves me right, there's a small rubber hose that supplies coolant to this--maybe it's come loose or cut/cracked.
    Tom
  3. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    The leak is lower down, towards the front and below the thermostat.
    O' just in case 1992 FJ80, 3FE.
    -H-
  4. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    My bad...on mine, the thermostat is on the PS front. I'm guessing that you've already checked and ruled out the metal heater pipe and associated gasket where they meet the block.
    I did have a water pump go a few thousand miles ago. It didn't spit out much coolant when sitting there, but there was no obvious sign of leaking from it either. My guess is that the water seals went in it and the coolant had leaked out via the vent hole on the pump. I don't know anything about your engine, so I don't know how similar the design is.
    Good luck.
    Tom
  5. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Thanks Tom,
    I've already crawled underneath it and ruled out the lower rubber water hose; the intermediate metal pipe just after it looks ok (coolant coming from above it), but I can't visually check the final upper rubber hose. On the 3F it doesn't appear to have a gasket. ???
    -H-
  6. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Ok, went ahead and ordered a new water pump, gasket and upper hose. (Now to figure out a time to put 'em in once they get here...)
    -H-
  7. BMT
    BMT
    325
    Apr 1, 2003
    I am not sure how different the configuration is between a 62 and an 80. On the 62 there is a short rubber hose that goes between the water pump and engine block. It is hard to see and even harder to get to. I will check with Steve to see how he relaced that hose on his 62.
  8. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Thanks! Any help is appreciated. I've only got Wednesday night and Friday to get this done, so I'm trying to get parts lined up.
    (This was much easier on the 350 in the 60....."Hello NAPA, I need a water pump.....twenty five bucks....cool, I'll be right down....")
    -H- :beer:
  9. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    And the winner is............ BMT! He wins some good quality #6s when he gets to Flagstaff next weekend!
    Got in there last night and sure enough, the bypass hose had a hole in it. Although I didn't order that part :slap: I was able to find a close replacement at NAPA.
    Back on the road.
    -H-
    (With a spare water pump for the Baja trip, BMT 8) )
