Want to install a Snorkel
Discussion in '40- & 55-Series Tech' started by Guest, Mar 23, 2003.
  1. Guest
    Guest Guest
    Looking to install a snorkel. Who would be the best sourse to purchase from and are there any pitfalls in the instalation?
    Is Safari the only sourse?
    Thanks,
    Russ
    85 FJ60 210k
    76 GL1000 83k
  2. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    I say make your own. There should be a write up in the tech section (if i remember correctly)
  3. Guest
    Guest Guest
    Is it a Diesel or Petrol Engine?
    If it is a Petrol, What is lower - Air Intake or Distributor? If the Distributor is lower than the Air Intake do not bother with a Snorkel.
    You should use a Blind in all water crossing no matter how shallow, Especially in a Diesel.
    Do not bother making your own or buying one and fitting it yourself, Water usually comes in via the Drain in the Air box or in Joins, If you get water in you can then blame the shop.
  4. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    remember snorkles are also good for cooler air, and less dust, not just water crossings. Also, you can waterproof alot of stuff like the dist.
  5. Guest
    Guest Guest
    The Toyota Landcruiser Club of Australia (Victoria) at the meeting about 5 weeks ago concluded that the Safari Snorkel is better than the Toyota optional Snorkel for the HZJ78.
