VSS buffer
Discussion in '40- & 55-Series Tech' started by Webster, Apr 10, 2003.
  1. Webster
    Webster
    236
    Feb 20, 2002
    Has anyone successfully built a working VSS buffer for the FJ60 to allow the signal to be usable by a GM ECM for TBI conversion?
  2. theo
    theo
    1,432
    Feb 19, 2002
  3. cruiserbrett
    cruiserbrett Moderator
    2,438
    39
    Feb 19, 2002
    San Diego
    Vortec not equal to TBI. Also, I think he is talking about making a buffer for the Toyota speed sensor in the speedo and GM ECM, not an speedo cable installed VSS.
    I tried to use my speed sendor in my FJ40 speedo and could never get a stable signal(optical vs magnetic) to the TPI ECM(similar to the TBI). I programmed a few PROMS trying to get it to work, but if it is not a magnetic pickup sensor, it does not play well with the ECM for some reason. You might have better luck with the TBI ECM('7747), and if you do post it up! Good info on the diy-efi.org site...
  4. theo
    theo
    1,432
    Feb 19, 2002
