Vent air is warm
Discussion in '80-Series Tech' started by Riley, Aug 16, 2003.
  1. Riley
    Riley
    1,613
    10
    Jun 20, 2003
    Fort Langley, BC
    I was out for the first time in my new 80 today and I noticed that the fresh air from the vents is warm (unless I have the AC on). TO be clear it's warmer than the air outside.
    My guess is that the air feeding the "fresh air" intake is getting "preheated" somehow from the engine compartment. After running for 10 minutes or so it cools down ( i think). My other idea is that the control for the rad hot water doesn't shut off correctly.
    Anybody ever notice this ? Is it normal?
  2. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    I notice that too. Just leave the A/C on all of the time.
  3. landtank
    landtank SILVER Star
    18,423
    597
    Mar 27, 2003
    Groveland MA
    Same here, it is especially bad if the truck has sat in the sun for a few hours. I wouldn't concern myself with the temp control as that usually will effect the air temp from the AC as well and it wouldn't cool off after a while, it would remain warm all the time.
  4. Seminole
    Seminole
    106
    Mar 28, 2003
    Check your heater control valve. Even with the A/C off and fresh air open, it can still affect the incoming air temp. There is a post a couple of weeks back on the procedure to check it. The FSM doesn't cover this in any detail (at least for a 91). If it is bad it is only about a 55-70 $ part.
    HTH ;)
  5. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Condition normal. It is not possible to completely stop coolant flow. In addition the instrument panel heats up and so does the air intake system. That being said, sigfificanty warmer than outside air could indicate a mis-adjustment of blend doors in the heater assembly or a heater valve that is bypassing more coolant than it should. You will notice when moving the temp control from hot to cold that the temperature changes quite rapidly. The reason for rapid as opposed to gradual change is the blend doors inside the heater box. These doors open and close to divert air around or thru the heater core as required.
    Dan.
  6. DLJ
    DLJ
    35
    Jul 15, 2003
    Dude ours is blowing warm all the time that the ac is not cranking.....man its gonna be great in the winter time......I thought it was just the f-ed up Auto Climate control's version of global warming......
