vc
Discussion in '80-Series Tech' started by thorvald, Aug 28, 2003.
  1. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    have read a couple posts about the viscous coupler recently and tire size.
    so, how much would running a spare of the same size tire, but different make effect it, in order to get somewhere to get it fixed?
    I ask as my tires are 32x11.5? i think, sport kings. my spare is a 31x10.50, which im going to be giving to my 60 and buying a matching size for the 80.
    i like my bfg a/ts and was thinking of going with the m/ts next set i buy. since the spare wont see much use would like to get something that can rotate with the next set. the sport kings have at least 50% tread on them though and are pretty decent in the mud.
    any thoughts?
    anyone know who makes the sport kings?
  2. Landpimp
    Landpimp GOLD Star
    14,682
    869
    Mar 14, 2003
    PNW
    if you running a 15" wheel I will assume you have a 91-2 fj80, if this is the case you don't a viscous coupler. Even if this is not the case running the same size but a different make........is no big deal.
    John
  3. DanKunz
    DanKunz
    8,855
    Media:
    2
    521
    Feb 7, 2002
    Woodstock, GA
    I agree with Landpimp...
    Fisk Tire makes the Sport Kings.
  4. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    Landpimp: it is a 91, good to know i dont have a viscous coupler :D
    what exactly does it do anyways?
    Dan, or anyone who might know: how do the sport king a/ts compare to the bfg a/t's or m/t's? Ive had the 80 since february and the sport kings have done good other than getting stuck in two feet of snow :D
    our driveway was a huge mudpit for a while and it did good not getting stuck, but im not sure if its the 80 and the weight or if the sport king a/ts are a better mud tire than the bfg. anyone?
  5. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    The VC works like the fan that cools the radiator. As the fluid in the coupler gets hot it turns to a solid and makes the fan turn. It is about the same with the VC, if one of the output shafts is spinning faster than the other, the VC locks (either do to friction or heat) and locks up the two shafts. The problem that I and some others have had is the VC locks up do to heat (it shouldn't do this) from normal driving. There is other types of VC, like on the Previa Van that are rebuildable but the 80 VC is sealed :-[
    I would be nice to know what is killing the VC. My guesses are:
    1)running with different size diameter tires
    2towed with the front or rear wheels off the ground, what would happen if you towed the 80 this way? Would the lifted wheels try to trun?
    3)or poor design from Toyoda
    My bet is #1)
  6. landtank
    landtank SILVER Star
    18,423
    596
    Mar 27, 2003
    Groveland MA
    Or the new owner decides to rotate in that unused spare on a set of very used tires.
  7. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    do 93's and up have the vc's?
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    If it is a FZJ80 yes FJ80 no
  9. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Kurt, not exactly.
    In 93 and 94 (FZJ80) is is possible to encounter a vehicle without ABS. these vehicles use the other transfer, drums on the rear and a semi floater. That was the "standard" configuration, ABS was an option. Starting in 95 ABS became standard.
  10. landtank
    18,423
    596
    Mar 27, 2003
    Groveland MA
    I beleive the determining factor is actually if it has ABS or not. With ABS=Yes W/O ABS=No.
  11. landtank
    18,423
    596
    Mar 27, 2003
    Groveland MA
    Step away from the monitor for a couple of minutes and look what happens.
  12. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Doesn't the 'Z' mean it has ABS,VC etc ?
    kurt
  13. landtank
    18,423
    596
    Mar 27, 2003
    Groveland MA
    I don't know this for sure but have always thought it denoted the motor change.
  14. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    [quote author=landtank link=board=2;threadid=4743;start=msg35992#msg35992 date=1062093555]
    [/quote]
    Maybe that is what I was thinking of.
    Didn't they make both FJ80 and Fzj80 in 93/94? If not I stand corected.
    kurt
  15. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    The "F" denotes the 3FE, the "FZ" denotes 1FZFE. "J80" is the body configuration ;)
