How will I know when I need to adjust the valve lash? Am I looking or listening for anything in paticular? Its a 97 with 155k and as far as I know its never been done.
Thanks all......
Thanks all......
I gather from that sage like wisdom that its in my best interest to move this to the top of my "to do" list Aside from a feeler gauge are there other unique tools ill need? any SSTs?
Thanks John
interesting. I had a valve grind recently as part of a h/g saga and they told me they set the tolerances on the valves to factory spec. i assume they didn't replace any pucks since i wasn't charged for any. how did they adjust it?
Check them real soon, record the numbers, and then check them on a regular schedule. I like 30K miles.
They're not adjustable valves. They can only be adjusted by changing the shims.
the adjustment at the machine shop is to shave off a little of the valve stem to get the correct distance.
When a valve and seat are ground, the valve stem "moves up" in the guide. If this is not addressed the valve will be too long. The machinist "nips" the top of the valve stem to true it and to restore the geometry.
Since this procedure puts us at the cam shaft...
Are there more aggressive cams that can be swaped in during this? Is there a performance gain to be had? At the expense of...???
