Vacuum shifter for transfer case
Discussion in '40- & 55-Series Tech' started by Bobsbash, Aug 29, 2003.
  1. Bobsbash
    Bobsbash
    43
    Aug 29, 2003
    Currently I am doing a V8 swap on my 3/69 fj40 and am curious if the Vacuum transfer shift assembly can be changed to mechanical? Has anyone done anything else to deal with this? Any help is appreciated. Thanks, Bob
  2. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Yes it can, AFAIK all you need is the linkage off of a 3spd case with manual shift.
  3. dd113
    dd113
    2,923
    1
    Jun 13, 2003
    The side assy that holds the Vac shift will interchange with both 3 spd and 4spd TC. The mech assy will also interchange. Basically 4 bolts, pull it off and replace. You will need the piviot point from the doner case as well as the linkage.
  4. Gus
    Gus SILVER Star
    1,127
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    As everybody has already stated, it's really easy, completely bolt-on. You can use 4-speed parts(linkage(s) and shift lever), you'll also probably need the t-case top cover as well(I did); replace the old gaskets and you're good to go.
  5. Bobsbash
    Bobsbash
    43
    Aug 29, 2003
    Thanks for the info, it looks like I will probably go that route.
  6. SPRDAV
    SPRDAV
    82
    Aug 11, 2003
    I have the same set up, but I left the vacuum shifter. I haven't had any problems. From my understanding the mechanical linkage will bind if the frame twists, hence the twin shifter from advanced adaptors. I put the vacuum line for the shifter to a full vacuum port on the top of the manifold behind the carb. Try it, it works great, with no expense.
  7. ScarboDP
    ScarboDP
    51
    May 30, 2002
    I'm actually doing the exact thing right now. So far it is exactly bolt on. The only thing though is that I'm not sure if you can use the linkage from a four speed. You might be able to but it seems to me IIRC that the 4 speed linkage is a little longer in one place or another than the 3 speed. Anyway just be sure.
  8. godzilla
    godzilla
    254
    Apr 20, 2003
    I have a sm465 in my fj40 with a 350 small block. I got the kit from classic cruisers for the manual shift t case.
  9. Bobsbash
    Bobsbash
    43
    Aug 29, 2003
    All this info is great. I will let you all know how it goes. Thanks again, Bob
