No issue here with Seq 150a, photoman bracket and pulley. I think it's over two years with the pulley and more with the 150A
Regarding how much power does it take to run the truck-I am speculating, but the ignition, A/C, fans, stereo etc probably use 10-20 amps. That's a guess. Modern cars use more due to all the electronic systems.
I personally feel it's beneficial to upgrade the electrical system: larger gauge wires (battery, grounds, alternator, and starter), second battery, and upgraded alternator.
NO. That isn't how it works. Let's say you have a partially discharged battery and start your truck. The voltage rises to say 14-14.5 volts in the system and the battery accepts charge at what ever rate that it can-usually much less than you would think, but let's say a 50 amp rate. As the battery becomes charged, internal resistance rises in the battery until it is fully charged and then it stops accepting charge. The rate of charge goes to zero because all of the lead sulfate has been converted to sulfuric acid and elemental lead. Up to say 14.5(up to 14.8 in some systems) volts or so, it sits there happily charged not accepting additional charge but not doing anything else either. All the electric power needed to run the ignition, fans, computer, stereo etc comes from the alternator which is making a constant voltage around 14 volts, and what ever the current demand is, up to it's maximum capacity.
Now if your voltage regulator breaks, and the alternator voltage goes to 20 volts (which it easily can) you get electrolysis of water on the battery plates and this kills the battery quickly, either by "boiling" off the water (it actually isn't boiling, it's hydrogen gas and oxygen gas being released). In a sealed battery the case will swell from the pressure and will usually vent the pressure before the case ruptures-note the vent on an AGM battery.
So you could have a 300 amp alternator that with a working regulator, would be perfectly safe for your batteries. You just need to ask if you need all the power.
So for NW WHeeler - you bring up the excellent example of a fridge running all night. Again, let's look at what happens. Your fridge draws 3 amps when running and it probably runs 1/3 of the time on a hot night. We'll call your non driving time 15 hours. So your fridge draws 3 amps for 5 hours-that's 15 amp hours, which will be replaced by your alternator in 15-30 minutes by your stock alternator, or 15-30 minutes by a 150 amp alternator. Sounds weird right? but your battery can only accept charge so fast, and it is the limiting factor in recharging. And in real life it's more complicated than that because the battery accepts a high rate of charge for the fist 80% or so and then slows down accepting the final bit of charge much more slowly. So the point is, the bigger alternator doesn't help you much.
I think the general consensus of 80 owners would agree that 70A stock alternators are not the ideal power level for those of us that have winches, amps, stereos, phones, inverters, fridges,light bars, etc. When I'm out I want to know that there is plenty of amps on tap to keep the batteries topped off full until I've stopped for the night, in the morning it's good to know that those batteries are topped off quick in the morning as well.
Hello,
I am planning for big trip in next summer and I would like to have the common combo on the back of the car - ARB fridge, lights, couple of water pumps, ARB compressor, some converter for laptops and camera chargers etc.
I have a stock alternator which is original and I just changed the brushes so I am thinking that prior to the big trip (next summer) it would be good idea either to change it or replace it. I see a lot of discussion about the Sequoia bigger alternator and customized bracket. My question is :
* what exactly is needed to have the upgraded alternator from Sequoia ? - alternator itself, maybe a new alternator connector
* do I really need to upgrade the alternator , I am electric an-alphabet and I am terrified just looking at wiring diagrams. I would love to keep it stock if possible
* is the bracket still being delivered
Few points:
* I have dual battery system from IPOR which uses sure power battery separator (Sure Power 12V Uni-Directional Battery Separator (100 Amp) - Part#: 1314)
I still need to figure out couple of things with my system. Namely these ones:
Thanks,
- I have 2 AWG cable between primary battery and separator and another 2 AWG between secondary battery and separator. These cables are not fused. I see a lot of people are using ANL fuses on these cables.
- What size of the cable should I use from battery to fuse boxe in back of the vehicle (there is some cable already installed , not sure why but it is routed to primary battery and shielded with 150A breaker )
- What baterries should I use - Currently I have DieHard Platinum AGM.
Jorge
Here are a few pictures of how to remove the old wires from the stock alternator connector.
There is a locking or retaining tab in the connector that I just pry out with a small screwdriver by putting the screwdriver in one of the slots shown in the picture. Once the locking tab is popped out the wires are just pulled or pushed out through the back of the connector.
View attachment 892566 View attachment 892567 View attachment 892568
