BenMara
Asian Redneck
alot of the higher rated amped alternators in stock housings run hot, packing more into a smaller package is what they do. Now if some one could adapt a GM alternator that would be nice, id go for a Powermaster ....
FWIW the Sequoia and Tundra 130A and 150A alternator rigs use the 140A Fusible Link...which is the same size on our 100's. It defies logic to me but then again who am I to argue with the likes of the Toyota design engineers
I have never actually seen the fusible links on a Sequoia (or a 100 series) but the diagrams I have seen show they might use a different type than the 80 series cruiser? First picture is a drawing of the underhood fusible link box from a Sequoia. In the picture, #2 (ALT Fuse 140A) illustrates a bolt in fusible link; not the wire type that is used in the 80 cruiser. Other picture shows a box type bolt in fusible link. The 140 amp would be maroon in color.
I never changed the bracket price so it is still the same from when the thread started. That price that mmm635 mentioned gets you the bracket and the Toyota electrical connector and shipping. The USPS shipping price is the only thing that has increased.
What you need then is either a Toyota part #27060-0F040 130 amp or a Toyota part# 27060-0F050 150 amp alternator. The 2003-2007 Toyota Tundra had up to the 130 amp. The Toyota Sequoia had a 130 amp or a 150 amp. In addition to take full advantage of the upgrade you need some larger wire to run from the alternator to battery positive and to run a larger ground from battery negative to the engine block. The positive wire should have a fuse in the line. So alternator, wire, fuse, and the time to do it.
Bill
Photoman,
I just want to make sure that the bracket that you sell only works to mount the 130 or 150 amp Tundra/Sequoia alternator to the 1FZ engine correct?
Thanks
So I've got my alternator and a bracket on the way. I'm wondering if anyone knows what the "M" pin does on the 150A alternator. I know it is not used as far as the 80 is concerned, but I'd still like to know what it could do.
Also, does anyone know where to source high current fusible links? I'd prefer that to a fuse, and I think mine is both failing and going to be too small.
Thanks,
JFS III
Where else are you all getting yours from?
There has been some questions as to how to do the wiring for this modification so I will post something here and some pictures, some of which will be redundant. I am not an electrical engineer so if I get something wrong please correct me.
Apologies to dial ups for the pictures.
The only wire that needs to be upgraded is the one that runs from the alternator to the positive post on the battery. If a person is running a single battery a new wire can just be run from the "B" post on the alternator through a fuse to the battery. The stock "B" terminal wire would still be connected to the alternator. Up by the battery is a plastic box marked AM1. Inside the box is a couple of large wires, one of which is the wire that comes from the stock alternator. This wire could be unbolted here or left connected as a parallel wire.
As far as wire size goes, it depends on the length of run of wire. As best I can determine with one battery in the stock location a number 4 wire should be the minimum. For dual batteries with longer runs something up to a 2/0 could be used. There are online charts for wire size and distance. Using a bigger wire size is almost always better.
Included is a picture of a some fuse connectors that would work. The holder takes fuses from 100 to 300 amp which are purchased separately. I understand the alternator should be fused at 20% over the capacity. Keep in mind the fusing is to protect the wires. So you can't put in a large fuse with a small wire or the wire will just burn up which is the thing we are trying to avoid.
More...
Bill
