Universal Recovery Brackets - URB's
Discussion in 'Accessories - Electronics - Recovery' started by Duiser Offroad, Oct 12, 2012.
  1. Duiser Offroad
    Duiser Offroad Supporting Vendor
    Jun 29, 2012
    1,390
    Portland, OR
    Universal Recovery Brackets - URB's 80 and 100 Series Land Cruisers
    $90.00 for 2
    Bolts directly to the factory recovery point locations front and rear. 1/2" shorter than stock recovery points for added clearance. These are made of powder coated 1/2" steel and accommodate a variety of clevis/ D-Ring designs and sizes.
    Working Load limit of 10,000 lbs
    Ultimate Strength of 20,000 lbs
    URB's include mounting hardware, grade 12.9 bolts. Does not include Clevis/ D-Ring.
    Buy at;
    www.duiser.com
    URB Install Video;
  2. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    Everyone keeps asking me how strong these brackets are. To answer your questions;
    1. We are in the process of having the brackets bench tested on a hydraulic press to find their breaking point.
    2. We are also in the process of finding the bracket's theoretical breaking point taking into account material, construction etc.
    3. We are in the process of having 2 Independent MUD field testers test our brackets as well as all who have already bought them, about 50 brackets so far.
    4. And finally, we have been field testing them ever since inception, we've posted videos of such.
    That said, these brackets are only as strong as what they are attached to eg your FRAME. The strength of the brackets and the supplied hardware far exceed the strength of any vehicle frame, including the land cruiser. THEY ARE 1/2" Steel!!
    I dare say, we are testing these brackets a hole lot more than anyone tests their custom bumpers/ recovery points.
    URB Install Video;
    I'll keep you all posted on the above mentioned results! :cheers:
  3. Wheelingnoob
    Wheelingnoob
    Apr 29, 2010
    4,517
    Langley BC
    How are the tests going? Waiting to order a set.
  4. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
  5. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
  6. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    URB Stress Analysis has been completed.
    A working load limit of 10,000 lbs provides a safety factor of (2) and coincides with readily available shackles. Additionally, 20,000 lbs reflects a yield within tolerance, not a failure.
    While we are proud of the above results, we suggest always utilizing more than one recovery point. This is not only safer but easier for recovery purposes.
    For those who have already purchased the URB, thank you. For those on the fence, here is your proof. :cheers:
  7. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    URB Stress Analysis
  8. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
  9. dogdaysindurham
    dogdaysindurham
    Aug 24, 2011
    165
    Durham NC
    Just installed 3 of the 4 URB I ordered from maxxmaven and jonesysoffroad. Fits awesome and came with all new bolts and washers. Fit and finish is great and they were very fast in shipping. Very happy and looking forward to using them when I head out to the North End this spring / summer.
    Side note: one nut is pretty stubborn on the rear left OE brackets and I'm hungry so the last one will go on tomorrow.
  10. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    Thanks! I hope you get some good use out of them! :cheers:
  11. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    A new bent URB coming soon. Bent, not welded. Super Clean!
  12. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    FREE SHIPPING MONTH OF AUG 2013.
    MENTION IN CHECKOUT TO RECEIVE DISCOUNT!!
    :cheers:
  13. Ebg18t
    Ebg18t
    Sep 1, 2013
    3
    Do these happen to bolt up to the gen4 4Runner?
  14. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    Not to our knowledge.
  15. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
  16. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    Free shipping for the rest of Sept and Oct!!!! Available for the 100 and 80 series Land Cruiser!! :bounce::bounce::bounce::bounce:
    Coupon Code "ooohhh yeah"
    :cheers:
  17. carbon60
    carbon60
    Sep 30, 2012
    65
    How do you use two recovery points, some kind of equalizer strap?
    Thanks,
    A.
  18. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    With a bridle. :cheers:
    FREE SHIPPING FOR THE END OF SEPT AND OCT!! ITS THE 1 YR ANNIVERSARY OF THE URB!!!
  19. Random Dan
    Random Dan
    Oct 14, 2013
    211
    Quick question regarding the URB: Is there a reason you used bent plate in stead of just using 1/2" angle? Is it stronger or just easier to produce?
    Thanks.
  20. Duiser Offroad
    Jun 29, 2012
    1,390
    Portland, OR
    FREE SHIPPING ON URB BUNDLES!! MARCH ONLY!!
    www.duiser.com
    LOOKING FOR A COOL AND FUNCTION ACCESSORY ITEM FOR YOUR 80 SERIES OR 100 SERIES LAND CRUISER? REPLACE YOUR STOCK TIE DOWNS WITH URB'S!!
    SEE VIDEO;
    :cheers:
      File size:
      3 KB
      111
Share This Page
