U-bolts, how tight?
Discussion in '40- & 55-Series Tech' started by Guest, Jan 12, 2003.
  1. Guest
    Guest Guest
    I am in the middle of putting on my sky jacker 4" kit on my 40 and was wondering how tight to torque the u bolts?
    thanks
  2. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    from haynes, 60 ft lb's
  3. Pin_Head
    Pin_Head
    13,740
    1,309
    Feb 6, 2002
    OC, CA
    The Toyota manual says about 100 ft lbs. Mo is bedda.
  4. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    Make sure to do each side evenly. If you just sit there cranking on one side, it will twist/not sit flat
  5. pfry
    pfry
    64
    Feb 17, 2002
    Torque them up as described by the previous replies, then do it again at least 2 more times.
    Seems like the dang things stretch a bit with use.
    I got a couple of turns on each after a few miles.I had new CCOT U-bolts and springs.
    paul
  6. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    initial torque, 80 ftlbs. after 1 week, retorque. one month later, re torque again....
    I've read 60-80-100 for u-bolts....not honestly sure which is correct. I've made a habit of overtorqueing mine...heh
  7. Halo3
    Halo3
    84
    Oct 11, 2002
    Denver, CO
    I asked a similar question when I did my 4" Skyjacker lift. In the end I went with 90 ft/lbs. As nothing stripped, I'm assuming that the nuts & bolts are happy with it. :)
    As Woody stated, re-torque them repeatedly. After my installation, I drove about 5 miles, and the next morning I ended up putting several turns on each & every nut. Since then, I have re-torqued them at least 6 different times. One thing that I can say is that each time I get a little less movement before the torque wrench clicks.
  8. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    if they are loose, you'll feel it. The car will kinda twist when you aply power, happened after like 4 miles of driving, retorqued and went away
  9. cruzila
    cruzila
    140
    May 10, 2002
    Garden Valley CA
    I hate that book
    minimum 80 ftlbs. I try to get them to 100. If it feels mushy at 80 on used ones replace them. you know, it is tight and you keep turning it, then it clicks.
  10. lndcrzr71
    lndcrzr71
    34
    Apr 20, 2003
    yo its about 90-95ft lbs :beer:
