it should.
Long before the shaft breaks the splines twist. The really bad twist is in the area between the collar and the spider gears. That is the area on the shaft that still has a hint of the splines showing.
If the shaft twists in this area there is absolutely no graceful way of removing the shaft even if it is broken unless the break is right up next to the locking collar where the stub won't interfere with removing the diff.
With the machined shaft if it was to break you should still be able to slide the stub section out through the collar and into the housing to be retrieved once the diff was removed.
